MOORADAN Posted October 28, 2014 Posted October 28, 2014 Hi Guys, I have used attributes for title block. When I opened the block edit it shows all the tags and prompts. But unfortunately when I save the block and start giving values in Title block one of the tag is not visible even not on the attribute editor. Visibility for that particular tag is normal and checked ATTDISP is 1... Please note all other tags is visible only one is not. Please help:unsure: Cheers Quote
MOORADAN Posted October 28, 2014 Author Posted October 28, 2014 Thank you for your reply... As per my understanding Attsync will show the default value. But my case is I dont have any value when I close the block but its in the block when I open the block editor. Once again I repeat, its effecting only one tag or one att text... Quote
steven-g Posted October 29, 2014 Posted October 29, 2014 Can you post the block, someone might find something, If it is an attribute you chave added to a block then it won't show up in existing blocks in your drawing unless you use Attsync as RobDraw suggests Quote
MSasu Posted October 29, 2014 Posted October 29, 2014 If one attribute is not visible both in drawing (although Invisible mode isn't activated), respectively in editor, then may be that it was set as Constant with no default value. Please check the block definition (commad BEDIT). Quote
RobDraw Posted October 29, 2014 Posted October 29, 2014 Thank you for your reply... As per my understanding Attsync will show the default value. But my case is I dont have any value when I close the block but its in the block when I open the block editor. Once again I repeat, its effecting only one tag or one att text... You are mistaken. Did you try it? If you make changes to the properties of attributes, i.e. layer, size, color, the changes will not be seen in the drawing until you sync. It does not affect the value assigned to the attribute. Quote
MOORADAN Posted October 30, 2014 Author Posted October 30, 2014 Thanks Guys... Especially Robdraw... That was a syncing issue... Cheers :) Quote
