kfir31 Posted November 8, 2014 Posted November 8, 2014 Hello. I´ve read a thread about it but I wasn´t able to replace F3 and F8 keys. First try: replacing F8 for "1" key. When I type "1" it does not appear on field, so I assume CAD does not accept it (?). Second try: "shift+1". Accepted, but when I type it in Model, it enters as a text command (?). I´d like to get some help here, please. Quote
ReMark Posted November 10, 2014 Posted November 10, 2014 You want to replace the F3 (OSnaps) and the F8 (Orthomode) keys with numbers? Why? What thread are you referring to? Was it here at CADTutor? What file are you editing? Quote
kfir31 Posted November 10, 2014 Author Posted November 10, 2014 Yes, toggle OSnap and Orthomode. I´d like to replace F3 and F8 for "1" and "2" - this way I can use it more quickly (to me the F3-F8 keys are uncomfortable) http://forums.autodesk.com/t5/autocad-2010-2011-2012/how-to-change-f3-and-f8-into-regualr-hotkeys/td-p/3577690 Quote
ReMark Posted November 10, 2014 Posted November 10, 2014 (edited) The keys are uncomfortable? What are you going to use to enable/disable OSnaps and Orthomode? The link you posted is basically a repeat of the question you posted here. I was hoping it contained some useful information regarding the reprogramming of the function keys in AutoCAD 2007. F3 and F8 are considered Temporary Override Keys. Instructions for modifying a temporary override key can be found in the Customization Guide in the section about Keyboard Shortcuts. Edited November 10, 2014 by ReMark Quote
SLW210 Posted November 10, 2014 Posted November 10, 2014 If the linked thread is any indication, the OP wants to reassign Osnaps and Ortho to the [1] and [2] keys and also indicated in post #3 in this thread "(to me the F3-F8 keys are uncomfortable)". That question was somewhat answered in the linked thread, you'll most likely need to use Ctrl+ to reassign. Quote
YZ Posted November 18, 2014 Posted November 18, 2014 If the linked thread is any indication, the OP wants to reassign Osnaps and Ortho to the [1] and [2] keys and also indicated in post #3 in this thread "(to me the F3-F8 keys are uncomfortable)". That question was somewhat answered in the linked thread, you'll most likely need to use Ctrl+ to reassign. I agree, a modifier key will need to be added. Because 1 is used for other inputs by AutoCAD it cannot simply be reassigned. Rather than editing the F3 override, I suggest you create a new one. In CUI right click on Keyboard Shortcuts and select "New Temporary Override". Then paste the F3 macro, and assign a keyboard combination. Not sure if this will be the same for you, but today I could only get SHIFT+1 to work,CTRL and ALT were not registering. That is using AutoCAD 2015. Quote
BIGAL Posted November 18, 2014 Posted November 18, 2014 I have preset osnap setting so we use numbers 39 99 etc no reason why you could not have zzz or 00 much easier than F keys to do to turn on or off osnap. Quote
ReMark Posted November 18, 2014 Posted November 18, 2014 It's much easier to press a "3" and a "9" or the number "9" key twice rather than a function key once? Thanks for my morning chuckle. Quote
YZ Posted November 18, 2014 Posted November 18, 2014 I have preset osnap setting so we use numbers 39 99 etc no reason why you could not have zzz or 00 much easier than F keys to do to turn on or off osnap. BIGAL, do the numbers set values to the OSMODE variable? Or simply toggle it on and off? 39 is my most common OSMODE value, which made me wonder... Quote
BIGAL Posted November 19, 2014 Posted November 19, 2014 Yz a little lisp just used simple number no real relevance to osmode 99=15359 (defun c:39 () (setvar "osmode" 39) ) Quote
