muck Posted November 10, 2014 Posted November 10, 2014 I have been using transparency in my drawings. Now I am seeing problems when I plot to a pdf using Adobe pdf drivers. The transparent layers have hidden linetypes & poor print resolutions. Is there a solution to this problem? Thank you, Quote
BlackBox Posted November 10, 2014 Posted November 10, 2014 In Page Setup manager, Modify your named page setup, and confirm that the 'Plot with transparency' box is checked (right side, under Plot options)...? Cheers Quote
muck Posted November 11, 2014 Author Posted November 11, 2014 When the above box is check the Transparancy layers are printed but they have poor resolutions with hidden line types. Quote
BlackBox Posted November 11, 2014 Posted November 11, 2014 When the above box is check the Transparancy layers are printed but they have poor resolutions with hidden line types. That is an entirely different issue, and unrelated to whether transparency is being incorporated into the resultant plot or not. Rather than Adobe driver, consider using 'DWG to PDF' instead. Cheers Quote
muck Posted November 11, 2014 Author Posted November 11, 2014 Company insist on using Adobe for some reason. Does dwg to pdf converter work better? Thank you, Quote
BlackBox Posted November 11, 2014 Posted November 11, 2014 Company insist on using Adobe for some reason. That is unfortunate. Does dwg to pdf converter work better? Going from personal experience, and nothing else... Yes, it does. It ships with AutoCAD OOTB, so it most definitely works better internally, and I've also found that it produces smaller PDF output as compared to that which spawns from Adobe driver (at same resolution), so it also takes up less space on server, email folders, and is faster to combine, etc. Now, in 2009 when DWG to PDF was first introduced, it was not so good... Since 2009 SP3, we've moved to DWG to PDF for all PDF output, and marry that to named Page Setups for use with AUTOPUBLISH Mechanism... Each time we upgrade Adobe, I check it against DWG to PDF, and the latter continues to win here. Test it for yourself, plot the same drawing(s) with each (at the same resolution), compare, and use (or ask to use) what's best for your environment. Cheers Quote
SLW210 Posted November 12, 2014 Posted November 12, 2014 Do the Plot Previews look correct? How do they look if actually plotted on paper? Like BlackBox, I seldom use the Adobe Driver, DWG to PDF works very well since the later 2009 version of AutoCAD. Can you post the troublesome files? Quote
f700es Posted November 12, 2014 Posted November 12, 2014 +1 on using DWG to PDF over Adobe when using transparency in PDFs Quote
