Flatshot operation did not generate any geometry.
anyone knows what causes this?
thx
Maybe it did but it just isn't evident? Did you do a zoom > extents?
yeah.... this is what is on the command line after it try's to exicute. ... just started (not) responding this way.
does flatshot work on blocks and xref's btw?
I don't see any reason why Flatshot wouldn't work on a 3D block if that is what you are asking.
want to test it but can't since it's not working.... curious if it's lack of memory (not counting mine of course)
Can you post a drawing that contains at least one of the objects you used Flatshot on?
I think it is relative to the size (complexity) of the drawing.
weird
By chance are they AEC Objects? I don't think they work with Flatshot.
I get that when trying to FLATSHOT a non-uniformly scaled block
you nailed it Nesly! I had one stinking block that way... thank you very much!
