Extract the attributes, and written table (help)
andy_lee
Try this and let me know how you would get on with it .
(defun c:Test (/ ss hgt pt n i sn tg lst l c r inc tbl st dups pns wrt nu)
 ;;    Author : Tharwat Al Shoufi                        ;;
 ;;    Date : 15. November. 2014                        ;;
 ;; Write a special kind of attributes to AutoCAD table        ;;
 (if
   (and
     (if (tblsearch "STYLE" "SIMPLEX")
       t
           (alert "Text Style < SIMPLEX > is not found in Drawing !")
           nil
     (princ "\n Select named blocks < TitleBar > :")
     (setq ss (ssget '((0 . "INSERT") (66 . 1) (2 . "TitleBar"))))
     (setq
       *hgt* (cond ((getdist (strcat "\n Specify Text Height < "
                                     (if *hgt*
                                       (rtos *hgt* 2 2)
                                       (rtos (setq *hgt* 1.0) 2 2)
                   (*hgt*)
     (setq pt (getpoint "\n Specify Base Point of Table :"))
      (setq hgt *hgt*
            n   -1
        (setq sn (ssname ss (setq i (1- i))))
        (mapcar
          '(lambda (x)
             (if (or (eq (setq tg (strcase (vla-get-tagstring x)))
                         "DRAWINGNO."
                     (eq tg "PARTNAME")
                     (eq tg "MATERIAL")
                     (eq tg "QTY")
               (setq lst (cons (vla-get-textstring x) lst))
          (vlax-invoke (vlax-ename->vla-object sn) 'getattributes)
        (setq l   (cons lst l)
              lst nil
      (setq l
             (vl-sort
               l
               '(lambda (n i)
                    (atoi (substr (setq st (cadr n)) (- (strlen st) 2))
                    (atoi (substr (setq st (cadr i)) (- (strlen st) 2))
      (or acdoc
          (setq acdoc (vla-get-activedocument (vlax-get-acad-object)))
      (setq c   5
            r   2
            inc -1
            tbl (vla-addtable
                  (vla-get-modelspace acdoc)
                  (vlax-3d-point (trans pt 1 0))
                  (+ (length l) r)
                  c
                  (* hgt 2.5)
                  (* hgt 2.5)
      (if (tblsearch "LAYER" "dim")
        (vla-put-layer tbl "dim")
      (mapcar
        '(lambda (h) (vla-setcolumnwidth tbl (setq inc (1+ inc)) h))
        (mapcar '(lambda (x) (* hgt x))
                '(5. 10.5 7. 7. 7.)
      (setq inc -1)
      (repeat (+ (length l) r)
        (vla-setrowheight tbl (setq inc (1+ inc)) (* hgt 1.2))
      (defun _settext (c st)
        (vla-settext tbl r c st)
        (vla-setcelltextstyle tbl r c "SIMPLEX")
        (vla-SetCellTextHeight tbl r c hgt)
        (vla-setcellalignment tbl r c acMiddleCenter)
        (vla-setrowheight tbl r (* hgt 1.2))
      (setq r 1)
      (mapcar '_settext
              (list 0 1 2 3 4)
              '("NO." "Drawing No." "Part Name" "Material" "Quantity")
      (setq r 2
            c 0
            i -1
      (foreach v l
        (if (or (member (cadr v) dups)
                (member (strcase (car v)) pns)
          (setq wrt (list (strcat "{\\C1;" (cadr v) "}")
                          (strcat "{\\C1;" (car v) "}")
                          (strcat "{\\C1;" (caddr v) "}")
                          (strcat "{\\C1;" (nth 3 v) "}")
                red t
          (setq dups (cons (cadr v) dups)
                pns  (cons (strcase (car v)) pns)
                wrt  (list (cadr v) (car v) (caddr v) (nth 3 v))
                red  nil
        (setq i (1+ i))
        (if (< i 10)
          (setq nu (strcat "0" (itoa i)))
          (setq nu (itoa i))
        (_settext
          c
          (if red
            (strcat "{\\C1;" nu "}")
            nu
        (foreach txt wrt
          (_settext (setq c (1+ c)) txt)
        (setq c 0
              r (1+ r)
Edited by Tharwat
  • Replies 60
  • andy_lee
    31
  • Tharwat
    22
  • hanhphuc
    7
  • hmsilva
    1
Posted Images
Thanks very much !Tharwat. You are my benefactor .:thumbsup:
Very nice! beautiful !
There is a little insufficient
1. I need the table layer is "dim"
2. and same name(PARTNAME, DRAWING NO) exists,but no pot-up tips, why?
You are welcome :)
I did not get it well , can you explain it in more details or with an image if that is easy for you ?
You are welcome :)
Same name, but without prompting
Maybe duplicate names, can use red font display .
Lots of changes considered in the above modified lisp routine , so try it and let me know .
CODES UPDATED ABOVE.
Master Tharwat, I appriciate your help! Thank you for your effort.
Near perfect!
DRAWING NO.duplicate Can identify .But PARTNAME duplicate can't identify.
Really ? what does the routine do then ?
Master Tharwat, the routine is very difficult to do it ?
Previous, must "DRAWING NO " is exactly the same , can check out , But two DRAWING NO is 1-SS706A-030 & 2-SS706A-030, It is not allowed in ERP.
Settle all your things of the program up first then write them all here clearly , otherwise I can not keep on guessing which is right and suitable for your needs .
I'm so sorry! sorry for my english. Master Tharwat.
your routine has reached 99.7% ,:D
0.1
0.2
0.3 If possible ,at last( after insert table), Deciding whether to output to xls(or csv)
This picture explaining what i mean. Hope that would be clearer.
Thanks so much! Master Tharwat.
01 : do you want to avoid including the duplicate drawing number into the table ? Show me with a sample drawing Before and After with the outcome you want .
02 : easy to add the BOM .
03 : you can export contents of any AutoCAD Table to Excel if you right click on the table and chose export ...
The DRAWING NO "2-SS706A-030" and "1-SS706A-030" ,the last(end) three digits is the same ! so need Red font .
This is the right.
Great!!!:thumbsup:
So you want the last two rows to be in red since there are with the same Drawing No. ?
you are right .
row 13 and row 14 have same Drawing NO. ,so row 14 need to be in red since .
[ATTACH=CONFIG]51622[/ATTACH]
Maybe you wanted to say 13 and 14 instead of ONLY 14 since they have the same Drawing No. in the two rows ?
