Bogbadbob658 Posted November 14, 2014 Posted November 14, 2014 I have a file with a large selection of blocks and I want to select a number of them using the block names. The blocks I want are named PTS-001, PTS-002 etc. when I select QSELECT I can't get the wildcard option to work the way I expect it to. If I put 'PTS' in it gives no returns and if I put 'PTS*' it selects all the blocks in the drawing including the ones without 'PTS' in the name. Quote
nestly Posted November 14, 2014 Posted November 14, 2014 Use an asterisk before and after the search criteria. Quote
ReMark Posted November 14, 2014 Posted November 14, 2014 +1 re: nestly's response. In testing other possible solutions I found that using a value of PTS-### also works. Quote
