Is it possible to export Navisworks files and edit (add text, numbers) in Auto cad 2014?
Someone suggested this as a possible solution at another website. I can't say if it works or not.
Take your Navisworks files and convert them into FBX format and then import that file into AutoCAD using the FBXIMPORT command.
Edited by ReMark
It's FBXIMPORT not FXBIMPORT...my bad.
Navisworks by default is a documentation tool, not a 3D modeling authoring tool. So the answer is no, however it seems ReMark might have found some sort of workaround that may be useful for your needs.
Thanks for replies, I will try your suggestion re Mark
Not to worry there Big G. I noticed I had transposed two letters when mentioning FBXIMPORT. Stuff happens. LoL
