mistergwapito Posted October 25, 2008 Posted October 25, 2008 can somebody help how to put the measure in angle 45 degrees? Quote
nocturne00 Posted October 25, 2008 Posted October 25, 2008 can somebody help how to put the measure in angle 45 degrees? Hi and welcome to the forums. not to answer your question (coz its a little vague) but it may be better to place your own question on a separate thread :wink: And maybe rephrase your question to be better understood Quote
skipsophrenic Posted December 15, 2008 Posted December 15, 2008 Are you on about in text or an angle dimension? Quote
ReMark Posted December 15, 2008 Posted December 15, 2008 From the pull-down menu at the top of your screen click on Dimension then click on Angular. Now, look at the command line. AutoCAD prompts you to Select arc, circle, line or : Therefore you must select some object(s). If you pick a line you'll then be prompted to pick a second line. You'll see that AutoCAD creates an arc with an arrowhead at each end between the two lines you've selected. The program then prompts for the location of this arc. Use you mouse to position the arc. AutoCAD will provide the angle based on the angle type and precision you have preselected using the Units command. Quote
