@arash136:
Use the built-in (distof) function.
  • 2 years later...
  • Replies 24
  • Hsanon
    8
  • Tharwat
    4
  • Lee Mac
    3
  • Ajmal
    3
On 22/11/2014 at 14:00, Tharwat said:
Try my program and let me know .
(defun c:mm2in (/ in ss)
 ;;    Author : Tharwat Al Shoufi .Date: 22.Nov.2014    ;;
 ;;    Converts Text Strings from Millimeter to Inch    ;;
 (if (setq in (/ 1. 25.4)
           ss (ssget "_:L"
                     '((0 . "TEXT,MTEXT")
                       (1 . "1*,2*,3*,4*,5*,6*,7*,8*,9*,x*,X*")
   ((lambda (x / sn e s a)
      (while (setq sn (ssname ss (setq x (1+ x))))
        (entmod
          (subst
            (cons
              1
              (if (wcmatch
                    (setq
                      a (strcase
                          (substr
                            (setq
                              s (cdr (assoc 1 (setq e (entget sn))))
                            1
                            1
                    "X*"
                (if (/= (atof (substr s 2)) 0.)
                  (strcat a (rtos (* (atof (substr s 2)) in) 4 0))
                  s
                (rtos (* (atof s) in) 4 0)
            (assoc 1 e)
            e
     -1
how to make mm to m
On 30/11/2014 at 22:38, Lee Mac said:
Hi Hsanon,
Try the following program:
([color=BLUE]defun[/color] c:mm2in [color=BLUE]nil[/color] (converttext ([color=BLUE]/[/color] 1.0 25.4) 4 0))
([color=BLUE]defun[/color] c:in2mm [color=BLUE]nil[/color] (converttext 25.4 2 2))
([color=BLUE]defun[/color] converttext ( f u p [color=BLUE]/[/color] e i n s x y )
   ([color=BLUE]if[/color] ([color=BLUE]setq[/color] s ([color=BLUE]ssget[/color] [color=MAROON]"_:L"[/color] '((0 . [color=MAROON]"TEXT,MTEXT"[/color]) (1 . [color=MAROON]"[1-9xX]*"[/color]))))
       ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] i ([color=BLUE]sslength[/color] s))
           ([color=BLUE]setq[/color] e ([color=BLUE]entget[/color] ([color=BLUE]ssname[/color] s ([color=BLUE]setq[/color] i ([color=BLUE]1-[/color] i))))
                 x ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 1 e))
           ([color=BLUE]if[/color] ([color=BLUE]wcmatch[/color] x [color=MAROON]"[xX]*"[/color])
               ([color=BLUE]setq[/color] y ([color=BLUE]chr[/color] ([color=BLUE]ascii[/color] x)) x ([color=BLUE]substr[/color] x 2))
               ([color=BLUE]setq[/color] y [color=MAROON]""[/color])
           ([color=BLUE]if[/color] ([color=BLUE]setq[/color] n ([color=BLUE]distof[/color] x 4))
               ([color=BLUE]entmod[/color] ([color=BLUE]subst[/color] ([color=BLUE]cons[/color] 1 ([color=BLUE]strcat[/color] y ([color=BLUE]rtos[/color] ([color=BLUE]*[/color] n f) u p))) ([color=BLUE]assoc[/color] 1 e) e))
   ([color=BLUE]princ[/color])
The commands are mm2in & in2mm.
Lee
How to run the code...
I have updated my earlier post to remove the visible BBCode formatting.
Firstly, thanks for your help. This very helps full for me
I just change this code to the millimeter to meter
am using this lisp for changing level. But this is not reding any positive or negative (+OR-)
if I will select +18.050 it will not come. I have to replace +. Can you help me to read this any positive or negative value also
