array curbstone along 3d polyline or spline
i want to show road edge curbstone as 3d view
i have the edge of the road as 3d polyline and the stone to be arrayed as 3d solids
so can any one help by autolisp
attached dwg and image
thanks friends
test.dwg
I am assuming that you are not using Civil 3D. It has this functionality already built in.
Have you looked into the SWEEP command? Native AutoCAD command.
regards,
Hippe013
yes i don,t use civil3d sweep command gives as i think one object along 3d polyine but if can be done through lisp will be very great
What software are you using?
Hard to help with no knowledge of program you are using.
What do you want the lisp to do? You need to be specific in your request. People reading this have no clue as to what you are looking for.
regards,
hippe013
P.S. SWEEP
You want a block placed repeatedly along a 3d pline yes ? Ie known length.
interval must be defined by the user so he can use the proper interval to suit block length
Easy whilst I dont have code you need a "get pts along pline at interval" 1st attemp 2d, 3d a bit harder. Then insert block at scale.
Another way try divide block make a block at actual length you will need to work out how many given L/Bl length this is manual but could be lisp.
