BIGAL Posted May 4, 2025 Posted May 4, 2025 Welcome aboard. Ignoring sheet sets for a moment it sounds like you need to set up the correct Fire & Securtiy DWT, this way your sheet sets should work. We had to use water board title blocks that was different to our company title block so we had more than one dwt. You are right may need to do a copy & paste between dwg's as a starting point. You can "Steal" layers & blocks from another dwg, to help set up the dwt., or bring in the required into the Fire & Security dwg. Hint Lee-Mac Steal.lsp. Quote
