BIGMIKE09281946 Posted December 13, 2008 Posted December 13, 2008 In the book MST_A_CAD_2k6 Chpt 17 I was told to delete the sink from the kitchen block. Then I was to use the Block Editor to create, save and insert a new Dynamic Sink with Linear parameters. After which I was told to add an Increment value, followed by a save and insert. All this is well and good, and I got a handle on the process. Trouble is, I was not told how to get it back into the kitchen block. A page or so later I discovered a better way to edit the darn thing. Is there a way to reassign the sink to the kitchen block? Quote
dbroada Posted December 14, 2008 Posted December 14, 2008 I'm not entirely clear what you are doing here. You have a kitchen block and within that block you have a dynamic sink block but the sink block hasn't updated? If the sink is within the drawing it should update automatically. If the sink is an external file re INSERT it from the modified source file. or something else? Quote
