BIGMIKE09281946 Posted December 14, 2008 Posted December 14, 2008 I have added stretch action to the right & left side of the 12 x 15 sink. The stretching is incremented by the value of 1 with a minimum of 9 and a maximum of 18. Works fine. I have added a drain to the center of the sink, and have added a .5 incrementing move in the direction to the right. Works fine! I cannot get it to move in the direction to the left. What's up wit dat? Quote
dbroada Posted December 14, 2008 Posted December 14, 2008 have you added a left 0,5 stretch? If not, post the block. Quote
BIGMIKE09281946 Posted December 14, 2008 Author Posted December 14, 2008 It works now, for some reason. Guess it was just missing a newer day. Thanks Dave. Did you see my other post "Block Head"? I'm having a problem re-inserting the sink, after having deleted it from the original block. There is no file for the sink so I think I will save the Sink as a file then re-insert it. Quote
BIGMIKE09281946 Posted December 14, 2008 Author Posted December 14, 2008 It doesn't work as a single file. It only works if I edit the sink block in the Kitchen block. If only I knew how to re-insert the sink. Thanks Dave Quote
