  • 1 month later...
  • Replies 25
  • Lee Mac
    15
  • gazzalp
    8
  • AustinTECH
    2
  • CAB
    1
I was wondering if anyone know how to combine these to lisp comands. One allows you to offset to both sides of a line and the other changes the line layer when you offset. Anyone have any ideas? What is a good way to learn how to creat lisp commands. Are there any books out there that anyone can suggest to read.
(defun c:doff(/ oldDis plSet plLst delFlg)
(vl-load-com)
(if(not doffdis)(setq doffdis 10.0))
(setq oldDis doffdis
doffdis(getdist
(strcat "\nSpecify offset distance
(rtos doffdis
(getvar "LUNITS")
(getvar "LUPREC")) ">: "))
); end setq
(if
(not doffdis)
(setq doffdis oldDis)
); end setq
(if
(setq plSet
(ssget
'((0 . "LWPOLYLINE,LINE,ARC,CIRCLE,ELLIPSE,SPLINE"))))
(setq plLst
(mapcar 'vlax-ename->vla-object
(vl-remove-if 'listp
(mapcar 'cadr(ssnamex plSet)))))
(foreach pl plLst
(vla-Offset pl doffdis)
(vla-Offset pl(- doffdis))
); end foreach
(initget "Yes No")
(setq delFlg(getkword "\nDelete source objects [Yes/No]? : "))
(if(null delFlg)(setq delFlg "Yes"))
(if(= "Yes" delFlg)
(mapcar 'vla-Delete plLst)
); end if
); end progn
); end if
); end of c:outline
(princ "\n*** Type DOFF for doubleside offset *** ")
_________________________________________________
(defun c:membrane (/ ent pt l1 l2)
(setq oldlay (getvar "clayer"))
(while (and
(setq ent (car (entsel "\nSelect object to offset 5 or :")))
(setq pt (getpoint "\nSpecify point on side to offset:"))
) ;_ end and
(if (not (tblsearch "Layer" "Membrane"))
(command "-layer" "m" "Membrane" "")
) ;_ end if
(command "._offset" 5.00 ent "_non" pt "")
(setq l1 (entlast))
(command "._offset" 10.00 ent "_non" pt "")
(setq l2 (entlast))
(command "_chprop" l1 "" "c" "cyan" "lt" "awthidden2" "la" "Membrane" "")
(command "_chprop" l2 "" "c" "red" "lt" "continuous" "la" "Membrane" "")
) ;_ end while
(setvar "clayer" oldlay)
) ;_ end defun
Would you like to keep the same Layer changing properties as shown in the posted LISP?
i.e.
Line 1
Layer = "Membrane"
Linetype = "awthidden2"
Colour = Cyan
Line 2
Layer = "Membrane"
Linetype = "continuous"
Colour = Red
Or would you like to specify your own?
For example, something like this could be modified to suit your needs:
(defun c:doff (/ oldDis plSet plLst entlst1 entlst2 delFlg)
 (vl-load-com)
 (if (not doffdis) (setq doffdis 10.0))
   doffdis    (getdist (strcat "\nSpecify offset distance <" (rtos doffdis
               (getvar "LUNITS")
               (getvar "LUPREC")) ">: ")))
 (if (not doffdis) (setq doffdis oldDis))
 (if (setq plSet (ssget '((0 . "LWPOLYLINE,LINE,ARC,CIRCLE,ELLIPSE,SPLINE"))))
      (setq plLst (mapcar 'vlax-ename->vla-object
           (mapcar 'cadr (ssnamex plSet)))))
      (foreach    pl plLst
    (setq entlst1 (cons (vlax-ename->vla-object (entlast)) entlst1))
    (vla-Offset pl (- doffdis))
    (setq entlst2 (cons (vlax-ename->vla-object (entlast)) entlst2)))
      (foreach ent entlst1
    (vla-put-color ent "1"))
      (foreach ent entlst2
    (vla-put-color ent "2"))
      (initget "Yes No")
      (setq delFlg (getkword "\nDelete source objects [Yes/No]? <Yes>: "))
      (if (null delFlg) (setq delFlg "Yes"))
      (if (= "Yes" delFlg) (mapcar 'vla-Delete plLst))))
 (princ))
cool that works, it would be cool of it uses the layer you have set current.
This puts the new lines on the current layer:
 (vl-load-com)
               (getvar "LUNITS")
      (foreach    pl plLst
      (mapcar '(lambda (x) (vla-put-color x 1)
                     (vla-put-layer x (getvar "clayer"))) entlst1)
      (mapcar '(lambda (x) (vla-put-color x 2)
                     (vla-put-layer x (getvar "clayer"))) entlst2)
      (initget "Yes No")
 (princ))
Let me know if you want the colours changed. :thumbsup:
