Assigning z value
Hi all,
I am trying to find a way to elevate 3d polyline vertex from nearest point z value -
Is there any way to do this?
Best Regards
If you need to elevate the entire polyline to a given elevation (so that all vertexes are at the same Z-value), you can do that through either the properties or quick properties panels, or you can use the MOVE command to move the polyline from 0,0,0 to 0,0,X where X is the desired Z-value for the polyline.
If you need to assign different Z values to individual vertexes of the polyline, I would convert the polyline to a Feature Line. You can then use the elevation editor from the contextual ribbon menu to edit the z values of each individual vertex on the feature line.
Hope this helps.
