yoyomankind Posted December 9, 2014 Posted December 9, 2014 Is it possible to create a dynamic block that arrays along a path? I'm trying to copy some arcs along a curved polyline, but can't seem to figure out which parameter/action combo to use for a path array. Quote
Dadgad Posted December 9, 2014 Posted December 9, 2014 Welcome to CADTutor. You might want to try one of Lee Mac's awesome lisps, http://www.lee-mac.com/objectalign.html If this one doesn't help you, he has lots of other great ones, and likely one of those will. Thanks Lee! Quote
adrath Posted December 9, 2014 Posted December 9, 2014 Something like this? I can't take credit for it, I found it in one of our old drawings at work. Not sure who made it and I haven't had time to really de-construct it to figure out how it works but it sounds like it may help you with what you're looking for. And if this doesn't help, then I second what Dadgad said. PARKING.dwg Quote
Dana W Posted December 16, 2014 Posted December 16, 2014 Is it possible to create a dynamic block that arrays along a path? I'm trying to copy some arcs along a curved polyline, but can't seem to figure out which parameter/action combo to use for a path array.Does the ARRAYPATH command help you? That is what it does, copys (arrays) objects along a path. Draw the path, draw one arc at the beginning of the path, type ARRAYPATH, select the object(s), select the path, and done. Then you can modify the incremental distance between the arrayed objects to suit you by clicking on the arrow grip of the array, pull the cursor a little bit along the path, and simply type in your desired incremental spacing distance, then hit enter. I would not think you need a dynamic block for this because that is what arraypath creates, a dynamic block. Quote
