narendra Posted December 10, 2014 Posted December 10, 2014 Hi All, my client has supplied a .lin file and I want to load in autocad how could I load..I know only way to load lines type is appload but once I load like this appearing on my cad files but not appearing on other systems what can I do to appear line types on all systesm of my group. Quote
dbroada Posted December 10, 2014 Posted December 10, 2014 I have no idea how to use LISP to load linetypes but from the command line you type -LINETYPE LOAD <name of file> Quote
ReMark Posted December 10, 2014 Posted December 10, 2014 Your lisp routine would have to include the path to the linetype file you want your users to load. I assume this would be on your network where the rest of your shared files are stored. Quote
BIGAL Posted December 11, 2014 Posted December 11, 2014 A lisp version Note the .lin file has been included in the "support files" list via CONFIG like Remark save to your server, else to one directory on every pc. (setq doc (vla-get-activedocument (vlax-get-acad-object))) (defun loadLinetype (doc LineTypeName FileName) (if (and (not (existLinetype doc LineTypeName)) (vl-catch-all-error-p (vl-catch-all-apply 'vla-load (list (vla-get-Linetypes doc) LineTypeName FileName ) ) ) ) nil T ) ) (defun existLinetype (doc LineTypeName / item loaded) (vlax-for item (vla-get-linetypes doc) (if (= (strcase (vla-get-name item)) (strcase LineTypeName)) (setq loaded T) ) ) ) ;load missing linetypes ;;; returns: T if loaded else nil (loadLinetype doc "Fence" "custom.lin") (loadLinetype doc "Tree" "custom.lin") Quote
Lee Mac Posted December 11, 2014 Posted December 11, 2014 My Load Linetypes function may also be of some interest. Quote
