duccioa
Field / additional format / conversion factor
duccioa
I run Autocad 2010 on Windows XP, eventhough I always had this problem and never could find a solution.
I have a problem when I copy a text with a surface field associated to a polyline. I have a drawing in cm but I need the surfaces to be in m², hence I use a conversion factor. I created the field and associated with the polyline. If I copy the field and associate it with a new polyline, I lose the settings of the conversion factor, so that everytime I copy it I have to reset the conversion factor.
Is there anyway to keep those settings?
Thank you
Duccio
Share this post
Link to post
