Hello everybody and sorry for my bad english!
This is a lisp routine that i created to insert a block with attributes. The first attribute is the current filename, without the file extension. I need the value of this attribute to be a field, not a text string, but I don't know how to modify the "fext" variable to do this.
The block name is Identifiant, and the attribute tag is PAEPCODE.
(defun c:ai ()
(vl-load-com)
   (setvar "luprec" 2)
   (setvar "clayer" "510_textes légendes")
   (if (= (setq txtcam (car (entsel "\n Nr camera: "))) nil)
       (setq nrcam "")
           (setq nrcam (cdr (assoc 1 (entget txtcam))))
           (prompt (strcat "\n" " " nrcam))
   (if (= (setq txttipcam (car (entsel "\n Tip camera: "))) nil)
       (setq tipcam "")
           (setq tipcam (cdr (assoc 1 (entget txttipcam))))
           (prompt (strcat "\n" " " tipcam))
   (if (= (setq txth (car (entsel "\n Inaltime camera: "))) nil)
       (setq hcam "")
           (setq enth (entget txth))
           (setq npr (cdr (assoc 1 enth)))
           (setq pcar (substr npr 1 4))
           (if (= pcar "HSFP")
               (setq hcam (substr npr 6))
               (if (= pcar "HSP ")
                   (setq hcam (substr npr 5))
                   (setq hcam npr)
           (prompt (strcat "\n" " " hcam))
       ;(setq hcam (cdr (assoc 1 (entget txth))))
   (setq nddw (getvar "dwgname"))
   (setq fext (substr nddw 1 (- (strlen nddw) 4)))
   (setq plli (CAR (ENTSEL "\nPick polyline: ")))
   (setq arrea (VLA-GET-AREA (VLAX-ENAME->VLA-OBJECT plli)))
   (command "insert" "Identifiant" pause "" "" "" fext nrcam tipcam arrea hcam "chauffé")
Edited by KataM
Welcome to CADTutor .
Firstly modify your codes to include the tag codes READ THIS
Back to your question , just replace the variable ftext with this "%%"
Thank you, that solved my problem. I only modify tc3 an fn7 with tc1 and fn2, like this:
(setq fext "%<\\AcVar Filename \\f \"%tc1%fn2\">%" )
