jakebullet70 Posted December 14, 2008 Posted December 14, 2008 Hi gays and gals. (using Autocad 2007) This one is making me crazy and it does not help I am new Autocad . I have a beam I need to place support 'chairs' underneath. So what I have so far is they can pick the beam and I get the X Y cords back. I convert the X Y to inches using this. '=============================================================================== Private Function Distance(Point1 As Variant, Point2 As Variant) As Double '--- '--- Returns the distance between two points '--- Dim dblDist As Double Dim dblXSl As Double Dim dblYSl As Double Dim dblZSl As Double '--- Calc distance dblXSl = (Point1(0) - Point2(0)) ^ 2 dblYSl = (Point1(1) - Point2(1)) ^ 2 dblZSl = (Point1(2) - Point2(2)) ^ 2 dblDist = Sqr(dblXSl + dblYSl + dblZSl) '--- Return Distance Distance = dblDist End Function This seems to work fine. Now I also have a minimum spacing that the support beams must respect. So if my beam is 8 feet (96 inches) and the minimum spacing is 12 inches I would need 8 support chairs. So the question is... How do I convert the inches back to the X Y cords for the insert? My insert code is this: '================================================================================================= Private Function InsertBlock(ByVal blockpath As String, ByVal rotation As Double, insertionPnt As Variant) Dim blockobj As AcadBlockReference '--- set rotation Angle rotateAngle = rotation rotateAngle = rotation * 3.141592 / 180# ThisDrawing.ActiveSpace = acModelSpace Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, blockpath, 1#, 1#, 1#, rotateAngle) 'Change Modelspace into Paperspace to insert the block into Paperspace End Function This seems good too. Any help will save what little hair I have left. Thanks is advance. Steve Quote
SEANT Posted December 14, 2008 Posted December 14, 2008 Something like this might serve the purpose. It has not undergone much testing, however. Function DivideSpan(ByVal varStPt As Variant, ByVal varEndPt As Variant, intDivisions As Integer) As Variant() Dim varTemp() As Variant Dim dblVect(2) As Double Dim dblDummy(2) As Double Dim i As Integer Dim j As Integer If UBound(varStPt) = 2 And UBound(varEndPt) = 2 Then On Error GoTo Abort dblVect(0) = (varEndPt(0) - varStPt(0)) / intDivisions dblVect(1) = (varEndPt(1) - varStPt(1)) / intDivisions dblVect(2) = (varEndPt(2) - varStPt(2)) / intDivisions intDivisions = intDivisions ReDim varTemp(intDivisions) For i = 0 To intDivisions For j = 0 To 2 dblDummy(j) = varStPt(j) + (dblVect(j) * i) Next varTemp(i) = dblDummy Next End If Abort: DivideSpan = varTemp 'calling routine should check for empty array End Function Quote
jakebullet70 Posted December 15, 2008 Author Posted December 15, 2008 Very cool!!!! Thanks a bunch!!! I removed the intDivisions = intDivisions as I did not see what that did. Again, thanks! Quote
SEANT Posted December 15, 2008 Posted December 15, 2008 Very cool!!!! Thanks a bunch!!! I removed the intDivisions = intDivisions as I did not see what that did. Again, thanks! Good idea. I don't know how that even got there. Quote
SEANT Posted December 15, 2008 Posted December 15, 2008 Now I remember. I was originally going to exclude the start and endpoints, by "ReDim"ming at intDivisions - 2, but changed my mind. Apparently I had started making some provisions for it. Quote
