Hello guys,
First I would like to thank you for this very useful forum. You've been helping me a lot.
But now I need a lisp that export the measure of each polyline's segment to excel. Something like the picture attached.
Thanks! :)
I've found there, but that routine has more than what I want.
I'd like one with just the Length of the segment. And, if possible, something that can select more polylines for the table, like the image attached before.
You want to export these segments' values or to select polylines and export each segment alone in a separate cell as shown in the Excel sheet ?
What about that L1 and L2 ? are they already existed or you want to name the exported polylines to have a reference of each row of value
to its polyline ?
to its polyline ?
I want with each segment alone, like the Excel sheet.
About the L1 and L2, they are just an example. For what I need, can be just a numeration in the order of each polyline selected, starting with 1.
Give this a shot and let me know .
(defun c:Test (/ *error* ss f o i l n in sn lst a d st)
;;;	Author : Tharwat 16.Dec.2014	;;;
;;; Write Polylines' segments to Excel	;;;
 (defun *error* (x)
   (if o
     (close o)
 (princ "\n Select Polyline :")
 (if (and (setq ss (ssget '((0 . "LWPOLYLINE"))))
          (setq f (getfiled "\n Save as :" (getvar 'DWGPREFIX) "csv" 1))
     (setq o (open f "w")
           i 0
           l 0.
           n 0
     (write-line "Ref No." o)
     (repeat (setq in (sslength ss))
       (repeat (fix (vlax-curve-getendparam
                      (setq sn (ssname ss (setq in (1- in))))
         (setq d (vlax-curve-getdistatparam sn (setq i (1+ i))))
         (if (< 0. l)
           (setq lst (cons (setq a (- d l)) lst))
           (setq lst (cons d lst))
         (if a
           (setq l (+ l a))
           (setq l (+ l d))
       (entmake (list '(0 . "TEXT")
                      (setq st (assoc 10 (entget sn)))
                      (cons 11 (cdr st))
                      (cons 40 (getvar 'TEXTSIZE))
                      (cons 1 (itoa (setq n (1+ n))))
                      (cons 7 (getvar 'TEXTSTYLE))
       (write-line
         (apply 'strcat
                (mapcar '(lambda (x) (strcat (rtos x 2 2) ";"))
                        (append (list n) lst)
         o
       (setq lst nil
             i   0
             l   0.
     (close o)
)(vl-load-com)
