capac Posted February 9, 2007 Posted February 9, 2007 I'm having a problem getting the hatch command to function. It works for everything except for "solid" fill. However, after I execute the command, it appears only when I'm hovering over the 'fill' area (model space). Fill mode is ON, and the 'solid fill' is set to 'front'. If I select a predefined pattern, it works great. I'm confused... Please help, -Aaron Quote
Barry_47 Posted August 19, 2014 Posted August 19, 2014 Dear capac pls understand fill and fillmode are two diffrent commands your fill should be on and fillmode should be set to 1 and you have to check after regenerate it. some time we are not be able to see our already filled object. Barry Quote
