designerstuart Posted December 19, 2014 Posted December 19, 2014 hi all we use blocks with attributes for title blocks in our drawings, and a few times recently the multi-line attributes have been moving from their insertion point. i'm not that knowledgeable about attributes, but i did create these blocks. i have read here that there is a VBA to fix it but do not know how to run this - well, i tried and nothing happened so not sure. do have a look at the attached dwg. it contains the block and a version that has been exploded. i would have thought the attribute xxx zzzzz would be positioned by the drawing_title attribute? basically, all the text should be centrally aligned. thanks for your help merry christmas! Drawing2.dwg Quote
designerstuart Posted January 5, 2015 Author Posted January 5, 2015 well that worked perfectly. thank you! Quote
