I made a custom toolbar. On this toolbar I put a Polyline tool. When I click this I want it to automatically put the polyline in the assigned layer.
Is this possible? :)
  • Replies 34
  • Lee Mac
    14
  • gazzalp
    11
  • Raggi_Thor
    3
  • TimZilla
    3
yes, what did you put in the button? I ask to help you put this ahead of it. A few questions, do you want a macro or LISP solution? If macro, add -layer;s;YourLayerNameHere;;YourPolylinemacroGoesHere
If you use LISP, you can capture what layer your on now, switch layers, draw the polyline, and switch back.
If you use palettes, you can do the same thing w/o the code
Could you add LAYERP to the end of the macro to return to the previous layer?
ok, if i go to tools/workspaces/customize/toolbars and then to my custom toolbar I am making.
inside those options I see a macro option and when I open the box to edit it it says
"^C^C_pline"
what would I need to add to that. Im new to this sort of thing.
ok I got it figured out, thanks!
That macro also helps me. One question, sometimes our layers go missing, so for example i want to put a dimension on the dimension layer, but there wont be one yet. So when i click on dimension it tries to automatically put it on dimension but cant find it. Is there a way i can make it make the layer "dimension"?
Thanks, one more thing; is there a way that when that macro has been used the current layer will go back to what it was originally. IE: if im on layer 0, and use a dimension, it puts the layer on dimension, but also changes my current layer from 0 to dimension.
Wouldn't all this be easier accomplished using LISP?
(defun c:dimtest (/ oldlay oldcmd)
   (setq oldlay (getvar "clayer"))
   (setq oldcmd (getvar "cmdecho"))
   (setvar "cmdecho" 0)
   (if    (not (tblsearch "Layer" "Dimension"))
   (command "-layer" "m" "Dimension" "")
   (setvar "clayer" "Dimension")
   ) ;_  end if
   (command "_dimlinear")
   (while (> (getvar "cmdactive") 0) (command pause))
   (setvar "clayer" oldlay)
   (setvar "cmdecho" oldcmd)
) ;_  end defun
Just send a call from the toolbar to the loaded LISP
Possibly, but even though youve given me the lisp for dimensions, i still have continue dimensions, hatch, text, viewports etc to do, and i already owe you a case of beer, i cant afford much more :P
layer;m;"dimension";;
should work...
I tried that, but what it does is bring up the layers (im guessing so i can add one). What id rather is have it add the dimension layer by itself, and then put the dimension on "dimension" is this possible?
Also still hoping someone knows a way of making the layer go back to the orginal once the item is inserted, instead of having a lisp routine for all the things i want changed (hatch, dimension, continue dimension, viewport, text)
Try this:
-layer;"m";"Dimension";;
I understand where you're coming from, but I'm not sure how you could accomplish resetting the layer with tapping into LISP - but maybe someone has already figured out a way to do it.
If you want to continue the LISP way - the posted LISP can be very easily modified to suit most commands.
Another thought - why not just use a reactor?
This is the reactor I posted on another thread - it will automatically change the current layer to a specific layer, then after the command has ended, or been aborted, the original current layer will return.
 ; Layer Director by Lee McDonnell
(vl-load-com)
(vlr-command-reactor
   nil
   '((:vlr-commandWillstart . startCommand))
) ; end command reactor
   nil
   '((:vlr-commandEnded . endcommand))
   nil
   '((:vlr-commandCancelled . cancelCommand))
(defun startCommand (calling-reactor startcommandInfo / thecommandstart)
   (setq thecommandstart (nth 0 startcommandInfo))
   (cond
   ((= thecommandstart "TEXT")
    (setvar "clayer" "TEXT")
   ) ; end condition 1
   ((= thecommandstart "MTEXT")
   ) ; end condition 2
   ((= thecommandstart "DTEXT")
   ) ; end condition 3
   ((= thecommandstart "DIMLINEAR")
    (setvar "clayer" "DIM")
   ) ; end condition 4
   ((= thecommandstart "DIMALIGNED")
   ) ; end condition 5
   ((= thecommandstart "DIMRADIUS")
   ) ; end condition 6
   ((= thecommandstart "DIMDIAMETER")
   ) ; end condition 7
   ((= thecommandstart "DIMANGULAR")
   ) ; end condition 8
   ((= thecommandstart "DIMORDINATE")
   ) ; end condition 9
   ((= thecommandstart "+VPORTS")
    (setvar "clayer" "DEFPOINTS")
   ) ; end condition 10
   ) ; end cond
) ; end startcommand
(defun endCommand (calling-reactor endcommandInfo / thecommandend)
   (setq thecommandend (nth 0 endcommandInfo))
   (cond
   ((= thecommandend "TEXT")
   ) ; end condition 1
   ((= thecommandend "MTEXT")
   ) ; end condition 2
   ((= thecommandend "DTEXT")
   ) ; end condition 3
   ((= thecommandend "DIMLINEAR")
   ) ; end condition 4
   ((= thecommandend "DIMALIGNED")
   ) ; end condition 5
   ((= thecommandend "DIMRADIUS")
   ) ; end condition 6
   ((= thecommandend "DIMDIAMETER")
   ) ; end condition 7
   ((= thecommandend "DIMANGULAR")
   ) ; end condition 8
   ((= thecommandend "DIMORDINATE")
   ) ; end condition 9
   ((= thecommandend "+VPORTS")
   ) ; end cond
) ; end endCommand
(defun cancelCommand (calling-reactor cancelcommandInfo / thecommandcancel)
   (setq thecommandcancel (nth 0 cancelcommandInfo))
   (cond
   ((= thecommandcancel "TEXT")
   ) ; end condition 1
   ((= thecommandcancel "MTEXT")
   ) ; end condition 2
   ((= thecommandcancel "DTEXT")
   ) ; end condition 3
   ((= thecommandcancel "DIMLINEAR")
   ) ; end condition 4
   ((= thecommandcancel "DIMALIGNED")
   ) ; end condition 5
   ((= thecommandcancel "DIMRADIUS")
   ) ; end condition 6
   ((= thecommandcancel "DIMDIAMETER")
   ) ; end condition 7
   ((= thecommandcancel "DIMANGULAR")
   ) ; end condition 8
   ((= thecommandcancel "DIMORDINATE")
   ) ; end condition 9
   ((= thecommandcancel "+VPORTS")
   ) ; end cond
) ; end cancelCommand
(defun makelay (lay / oldlay)
   (if    (not (tblsearch "LAYER" lay))
       (command "-layer" "m" lay "")
       (setvar "cmdecho" 1)
   ) ;_  end progn
   ) ;_  end if
) ;_  end defun
(mapcar 'makelay '("TEXT" "DIM" "DEFPOINTS"))
The above can be modifed to suit different layer structures.
As with lisps, im not very familiar with reactors. Ill try that reactor out, but how do i use it? IE how do i set it to work for lets say single line text? Remember i have no idea how it works, so i need to know how to load it, if i save it like i do with lisps etc. Thanks Lee
With the reactor, save it to a notepad doc (.lsp), just like a LISP, and just load it on ACAD start-up. As its a reactor, it has no syntax to type - it runs automatically.
You may need it modified to suit your layer structure, but experiment with it and see if its something you want to use.
Looks good Lee. One request, could you also add Hatch to that please? i only use the single hatch command, and i want it on a layer called "Hatch"
Also Lee, i have found after i do a viewport, it doesnt change the layer back to the original state. Ill play around with it myself and hopefully fix it, but if not could you have a look at it please?
Lee, ive used my absolutely superior skills to figure out how to do the hatch myself :P. I owe everything to you though :P One problem is i see youve added the ability to add the layers if they are not present in the DWG, i tried literally adding in the words "hatch" where i thought it would go so it works for hatch as well, but for some reason it doesnt. Also when it makes the "Text" layer could we somehow set it to the colour yellow not the white that comes up? so my 3 problems are:
1. Hatch layer wont be added to drawing if not there already.
2. Text layer change to yellow.
3. Defpoints not changing to old layer when viewport has been put on.
This is my code:
(vl-load-com)
   nil
   nil
   nil
   (cond
   ) ; end condition 1
   ) ; end condition 2
   ) ; end condition 3
    (setvar "clayer" "DIMENSIONS")
   ) ; end condition 4
   ) ; end condition 5
   ) ; end condition 6
   ((= thecommandstart "DIMCONTINUE")
   ) ; end condition 7
   ) ; end condition 8
   ((= thecommandstart "QLEADER")
   ) ; end condition 9
   ((= thecommandstart "BHATCH")
    (setvar "clayer" "HATCH")
   ) ; end condition 11
   ) ; end cond
   (cond
   ) ; end condition 1
   ) ; end condition 2
   ) ; end condition 3
   ) ; end condition 4
   ) ; end condition 5
   ) ; end condition 6
   ((= thecommandend "DIMCONTINUE")
   ) ; end condition 7
   ) ; end condition 8
   ((= thecommandend "QLEADER")
   ) ; end condition 9
   ((= thecommandend "BHATCH")
   ) ; end cond
) ; end endCommand
   (cond
   ) ; end condition 1
   ) ; end condition 2
   ) ; end condition 3
   ) ; end condition 4
   ) ; end condition 5
   ) ; end condition 6
   ((= thecommandcancel "DIMCONTINUE")
   ) ; end condition 7
   ) ; end condition 8
   ((= thecommandcancel "QLEADER")
   ) ; end condition 9
   ((= thecommandcancel "BHATCH")
   ) ; end cond
   ) ;_  end progn
   ) ;_  end if
) ;_  end defun
(mapcar 'makelay '("TEXT" "Dimensions" "DEFPOINTS"))xt" "Dimensions" "Defpoints"))
I have updated the LISP to include this.
Again, LISP has been updated to include this.
I don't seem to have this trouble: I go to View>Viewports>New Viewport> then I draw the viewport and upon finishing drawing my viewport, the layer will revert back to the original.
Anyway, try this:
 ; V1.1 Hatch, QLeader Commands Added, Layer Construction Updated.
(vl-load-com)
   nil
   nil
   nil
   (cond
   ) ; end condition 1
   ) ; end condition 2
   ) ; end condition 3
    (setvar "clayer" "Dimensions")
   ) ; end condition 4
   ) ; end condition 5
   ) ; end condition 6
   ) ; end condition 7
   ) ; end condition 8
   ) ; end condition 9
   ) ; end condition 12
   ) ; end cond
   (cond
   ) ; end condition 1
   ) ; end condition 2
   ) ; end condition 3
   ) ; end condition 4
   ) ; end condition 5
   ) ; end condition 6
   ) ; end condition 7
   ) ; end condition 8
   ) ; end condition 9
   ) ; end cond
) ; end endCommand
   (cond
   ) ; end condition 1
   ) ; end condition 2
   ) ; end condition 3
   ) ; end condition 4
   ) ; end condition 5
   ) ; end condition 6
   ) ; end condition 7
   ) ; end condition 8
   ) ; end condition 9
   ) ; end cond
   ) ;_  end progn
   ) ;_  end if
) ;_  end defun
(mapcar 'makelay '("Dimensions" "DEFPOINTS" "HATCH"))
(if (not (tblsearch "LAYER" "TEXT"))
   (setq oldlayer (getvar "clayer"))
   (command "-layer" "m" "TEXT" "c" "2" "TEXT" "")
   (setvar "clayer" oldlayer)
   ) ;_  end progn
) ;_  end if
