hi to all,
i got a new job..... all day in front of computer using autocad LT 2000.... most of the time we input a value that has a superscript of sometimes subscript.... what's the easiest way to do this in autocad?
thanks a lot in advance!
In mtext, the "^" symbol stacks fractions without any lines -- so if you type "3^ " (note the space), you get a superscript of 3. Putting the space first makes a subscript. I don't think you can do this in single-line text, though (without actually having two pieces of text).
thanks but i can't get any of the subscript or superscript with that ^
if i type
daryl 3^
i would get the same... as i type in.... using mtext.... the same in single line text
is there another way?
thanks
sorry for the delay of my response.....
Sorry, looks like I forgot a step. Once you've typed in "3^ " in mtext, you have to highlight it, then click the "stack" button. (Or right click and select "stack.") Hope that works for you... :-)
thanks i got it..... I can now create a superscript and subscript...
for the other who also want to know how....
for superscript i type
daryl 3^
then highlight and riht click on the 3^... the superscript of 3 is done....
for the subscript
daryl ^3
highlight the right click the ^3..... for subscript.....
Kate M thanks again..... can you share me other character done with stack..... thanks a lot!
As far as I know, there are just three types of stacks. From the help file:
Slash (/) stacks text vertically, separated by a horizontal line.
Pound sign (#) stacks text diagonally, separated by a diagonal line.
Carat (^) creates a tolerance stack, which is not separated by a line.
You can set the Autostack properties to control which options are used -- mine automatically turns "/" fractions into diagonal ones.
One more note: Versions below 2000i don't support diagonal fractions -- just vertical ones.
Glad it worked for you. :-)
  • 13 years later...
Hi,
I am trying to write d2uw/dy2, this is the second derivative of of uw over y.
Now d2uw (2 is superscript and w is subscript) is straight forward (using ^ and staking option), Problem is I can't write d2uw / dy2 in a horizontal fraction format.
Anyone has an idea on how you can superscript, subscript and have it all in a horizontal fraction ?
Many thanks in advanced
HC2020
HC202: Please do not double post. It just leads to confusion. See the thread you started. Thank you.
BTW...this thread is 13 years old. Thread necromancy is not encouraged.
