Ixoye Posted December 23, 2014 Posted December 23, 2014 I am running c3d 2014 and am having trouble with editing and creating Sub-Assemblies. I had found that there was a program called Autodesk Sub-Assemblies Composer. I was wondering if it is compatible with 2014? It would sure help me if it was. Quote
adrath Posted December 23, 2014 Posted December 23, 2014 Yes, the subassembly composer is compatible with 2014 and it *should* be installed if you have Civil 3D. "Should" being the operative word. It's not very simple to use, however. Creating custom sub-assemblies can be very helpful, but it's also very tedious and very time-consuming. And it's really frustrating when it doesn't work exactly right. I'm not saying don't do it, but you may be better off just working with the default sub-assemblies. What do you need your assembly/sub-assembly to do? Quote
Ixoye Posted December 23, 2014 Author Posted December 23, 2014 I have created an assembly and need to have a specific "Curb and Gutter" sub-assembly which style is from a manufacture and is not a C3d standard. I had tried creating one from a polyline but am not able to figure out the codes and links. Quote
