guitarguy1685 Posted December 23, 2014 Posted December 23, 2014 So I know how to get the date from autocad using CDATE. And I know how to parse that info to get 12/23/14. But how can I, for example, get the 12 to be "DEC". Do I need to make a multiple if statement for that part of the string? Quote
hanhphuc Posted December 23, 2014 Posted December 23, 2014 So I know how to get the date from autocad using CDATE. And I know how to parse that info to get 12/23/14. But how can I, for example, get the 12 to be "DEC". Do I need to make a multiple if statement for that part of the string? you can use.. (cond (1 "JAN")(2 "FEB")....) my example using mapcar (defun mth ( m / i l) ;hanhphuc 24/12/2014 (setq i 13 ) (eval (cons 'cond (mapcar '(lambda (a b /) (list (eval (cons '= (list m 'a))) b)) (repeat 12 (setq l (cons (setq i (1- i)) l))) '("JAN" "FEB" "MAR" "APR" "MAY" "JUN" "JUL" "AUG" "SEPT" "OCT" "NOV" "DEC") ) ;_ end of mapcar ) ;_ end of cons ) ;_ end of eval ) functional call: (mth 12) ; returns "DEC" since you know coding, so the rest try it yourself using string function strcat , substr , vl-string-search etc.. p/s: i'm ibanez fan merry X'mas donate to CADtutor Quote
ymg3 Posted December 24, 2014 Posted December 24, 2014 guitarguy1685, Alternatively, simply create an assoc list like so: (setq month '((1 . "JAN")(2 . "FEB")(3 . "MAR")(4 . "APR") (5 . "MAY")(6 . "JUN")(7 . "JUL")(8 . "AUG") (9 . "SEP")(10 . "OCT")(11 . "NOV")(12 . "DEC")) ) Now whenever you need the month just issue: (cdr (assoc 3 month)) will return "MAR" etc. ymg Quote
hanhphuc Posted December 24, 2014 Posted December 24, 2014 Now whenever you need the month just issue: (cdr (assoc 3 month)) will return "MAR" etc. ymg 1+ season greetings: ymg, i'd like to take this opportunity to credit some of your sub-functions i used in this forum. thank you merry X'mas hanhphuc Quote
ymg3 Posted December 24, 2014 Posted December 24, 2014 (edited) hanhphuc, Season's greeting ! to you too and all the best. ymg Edited December 24, 2014 by ymg3 Quote
Tharwat Posted December 24, 2014 Posted December 24, 2014 Another , (nth (1- 12) '("JAN" "FEB" "MAR" "APR" "MAY" "JUN" "JUL" "AUG" "SEP" "OCT" "NOV" "DEC")) Quote
AIberto Posted December 25, 2014 Posted December 25, 2014 ;;date-->cdate ;;;;http://bbs.mjtd.com/thread-112484-1-1.html (defun Date->CDate (date / s) (setq s (strcat "M=$(edtime," (rtos date 2 ",YYYYMODD.HHMMSS)")) (atof (menucmd s)) ) ;defun ;;cdate-->date ;;;;http://bbs.mjtd.com/thread-112484-1-1.html (defun CDate->Date (cdate / Round Time Diff cd dt i0 i n s) (defun Round (x) (if (>= x 0) (fix (+ x 0.5)) (fix (- x 0.5)) ) ;if ) ;defun (defun Time (dt / x h m s) (setq x (Round (rem (* dt 1E6) 1E6))) (setq h (/ x 10000) m (/ (rem x 10000) 100) s (rem x 100) ) (/ (+ (* 3600 h) (* 60 m) s) 8.64E4) ) ;defun (defun Diff (cd1 cd2 / y1 y2 m1 m2 d1 d2 n) (cond ((= cd1 cd2) (setq n 0)) ((setq y1 (/ cd1 10000) m1 (rem (/ cd1 100) 100) d1 (rem cd1 100) y2 (/ cd2 10000) m2 (rem (/ cd2 100) 100) d2 (rem cd2 100) n (Round (+ (* 366 (- y1 y2)) (* 30.5 (- m1 m2)) (- d1 d2))) ) (and (= n 0) (setq n nil)) ) ) ;cond n ) ;defun (setq cd (fix cdate) dt -47130101 i0 0 n 0 ) (while (and (setq i (Diff cd dt)) (/= i 0) (/= 0 (+ i i0))) (setq n (+ n i) s (strcat "M=$(edtime," (itoa n) ",YYYYMODD)") dt (atoi (menucmd s)) i0 i ) ) ;while (if (or (not i) (= 0 (+ i i0))) (setq n nil) ) ;if (and n (setq n (+ n (Time cdate)))) n ) ;defun Quote
hanhphuc Posted December 25, 2014 Posted December 25, 2014 (edited) Another , (nth (1- 12) '("JAN" "FEB" "MAR" "APR" "MAY" "JUN" "JUL" "AUG" "SEP" "OCT" "NOV" "DEC")) Thanks Tharwat. simple & clean This similar but it index nth in a string (menucmd (strcat "M=$(index, " (itoa (1- i)) ; i= integer " ,\"JAN,FEB,MAR,APR,MAY,JUN,JUL,AUG,SEPT,OCT,NOV,DEC\")" ) ) Edited December 25, 2014 by hanhphuc Quote
Tharwat Posted December 25, 2014 Posted December 25, 2014 Thanks Tharwat. simple & clean You are welcome anytime Quote
pBe Posted December 26, 2014 Posted December 26, 2014 Another , (nth [b](1- 12)[/b] '("JAN" "FEB" "MAR" "APR" "MAY" "JUN" "JUL" "AUG" "SEP" "OCT" "NOV" "DEC")) That would be (1- n) Be mindful of the index number, or (0-11) nth 0 is the first element, it might confused the OP. Quote
hanhphuc Posted December 26, 2014 Posted December 26, 2014 That would be (1- n) Be mindful of the index number, or (0-11) nth 0 is the first element, it might confused the OP. pBe actually Tharwat applied decrease , (1- n) ie: (1- 12) =11 th but it also looks like (1 - 12), OP maybe confused if not coloured tag Quote
pBe Posted December 26, 2014 Posted December 26, 2014 pBe actually Tharwat applied decrease , (1- n) ie: (1- 12) =11 th but it also looks like (1 - 12), OP maybe confused if not coloured tag Oh i see, its must be my eyes.. Thank you for clarifying hanhphuc. kudos to Tharwat Personally i prefer an association list to avoid confusion such as the one above. Quote
Tharwat Posted December 26, 2014 Posted December 26, 2014 Thank you hanhphuc for the clarifications , appreciated alot Thank you for clarifying hanhphuc. kudos to Tharwat Thank you pBe Quote
hmsilva Posted December 28, 2014 Posted December 28, 2014 So I know how to get the date from autocad using CDATE. And I know how to parse that info to get 12/23/14. But how can I, for example, get the 12 to be "DEC". Do I need to make a multiple if statement for that part of the string? Hi guitarguy1685, a different approach, not using 'CDATE' but also getting the date format as your exemple '23DEC13' (menucmd "m=$(edtime,0,ddmonyy)") ;; returns "28Dec14" ;; if uppercase is required (strcase(menucmd "m=$(edtime,0,ddmonyy)")) ;; returns "28DEC14" I hope this helps Henrique Quote
Lee Mac Posted December 29, 2014 Posted December 29, 2014 (strcase(menucmd "m=$(edtime,0,ddmonyy)")) ;; returns "28DEC14" This is the method I would have suggested Nice one Henrique Quote
hmsilva Posted December 29, 2014 Posted December 29, 2014 This is the method I would have suggested Nice one Henrique Thank you, Lee Cheers Henrique Quote
