Dear ymg3,
you are right - the thing which I need it actually an catenary. In my case, I mentioned parabola as for not quite big spans this does not make much of a difference.
Can you please tell me the units you have specified into your input data?
Do you have the tension in kN or MPa? I guess that is in MPa as you do not ask for the cross section of the conductor.
The weight per unit length - is it in kg/m, N/m or N/m*mm^2?
The eq for y values which I would like to be using is: Y=(specificload*x^2) / (8 * Sigma).
The specific load is in N/m*mm^2 and Sigma is in MPa.
Tomorrow morning I will go deep into the script and check this by myself.
  • Replies 23
  • ymg3
    6
  • motee-z
    5
  • hanhphuc
    5
  • sadefa
    5
Posted Images
  • 3 weeks later...
ymg3,
can you please help me modify the lisp so that it can work with differenet X and Y scales. The OHTL lines are often in different scales for x and y. For example for lenght 5000 and for hight 500.
I cannot get where I have to integrate the scale ration into the lisp.
safeda,
All you need to do is to multiply your Y by 10
while keeping the x at 1:1
(setq pl (cons (list x (* 10  (+ (* c (- (cosh (/ (- x xv) c)) 1)) yv))) pl)
Can't help you more than this as I am traveling.
ymg
