Madruga_SP Posted December 29, 2014 Posted December 29, 2014 Hi, I'm using autocad civil 2015. Where can I find survey data collection link? Regards Quote
BlackBox Posted December 29, 2014 Posted December 29, 2014 The Survey Data Link Extension needs to be installed, and is pre-selected in typical installation settings. Cheers Quote
Madruga_SP Posted December 29, 2014 Author Posted December 29, 2014 Hi Black Box Thanks for the quick replay. I saw that article, but I've tried to find that extension when I installed and I didn't find it. Help me, please! Quote
Murph_map Posted December 30, 2014 Posted December 30, 2014 The same place you go to do a repair install but use the Add features button. Control Panel, Autocad Civil3d Change/uninstall. Just click on the next button in the first dialog box after you select the add features. Quote
Madruga_SP Posted December 30, 2014 Author Posted December 30, 2014 (edited) hi, The uninstall button isn't work. There isn't the option that you told me. Edited December 30, 2014 by Madruga_SP Quote
Murph_map Posted December 30, 2014 Posted December 30, 2014 Go to your Windows Control Panel > Programs and Features > Right Click on the Autodesk AutoCAD Civil 3D 2015, Unistall/Change then click on Add or Remove Features. https://screencast.autodesk.com/main/details/17efd1a7-37f9-421e-8198-555bbebeaafc Quote
Madruga_SP Posted December 30, 2014 Author Posted December 30, 2014 Hi my friend, I did exactly you told me. But the extension is already installed. I don't know how to find it in my autocad civil 2015-metric. How Can I find it? regards Quote
BlackBox Posted December 30, 2014 Posted December 30, 2014 I don't know how to find it in my autocad civil 2015-metric. How Can I find it? Use the STARTSURVEYLINK Command, or on the Ribbon, go to Home tab, Create Ground Data panel, Survey Data Collection Link button. Cheers Quote
Madruga_SP Posted December 30, 2014 Author Posted December 30, 2014 (edited) Thank you BlackBox worked. Now I have to learning how to use it, because isn't worked as I expected to. Does anybody have a instrution how to use it? regards Edited December 30, 2014 by Madruga_SP Quote
BlackBox Posted December 30, 2014 Posted December 30, 2014 Does anybody have a instrution how to use it? Perhaps you should give this a read. Cheers Quote
