tamariz Posted December 30, 2014 Posted December 30, 2014 (edited) Hello; I am looking for a LISP allows selecting multiple polylines to extract their lengths to the attributes tag ( "length" ) blocks as fields , knowing that at each end of the polyline is the block in question ( where is the attribute tag). I found a LISP Lee Mac but it does not match my expectations because I have to select one by one each string and each attribute. (defun c:Len2Fld ( / *error* tables doc spc p s q ExitFlag ) (vl-load-com) (while (defun *error* ( msg ) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ) ) (setq tables (LM:ss->vla (ssget "_X" '((0 . "ACAD_TABLE"))))) (LM:ActiveSpace 'doc 'spc) (cond ( (setq p (LM:Selectif (lambda ( x ) (vlax-property-available-p (vlax-ename->vla-object x) 'Length ) ) "\nMétré longeur, Selectionner cable: " nil ) ) (setq s (strcat "%<\\AcObjProp Object(%<\\_ObjId " (LM:GetObjectID doc (vlax-ename->vla-object p)) ">%).Length \\f \"%lu6\">%" ) ) (while (progn (or ExitFlag (progn (initget "Point") (setq p (nentsel "\nSelect Text, MText or Attribute for Result [Point] <Exit> : ")) ) ) (cond ( ExitFlag nil ) ( (vl-consp p) (if (wcmatch (cdr (assoc 0 (entget (car p)))) "ATTRIB,*TEXT") (vla-put-TextString (vlax-ename->vla-object (car p)) s) (princ "\n** Object Must be Text, MText or Attribute **") ) ) ) ) ) ) ) (vla-regen doc AcActiveViewport) (princ) ) ) (defun LM:ActiveSpace ( *doc *spc ) (set *spc (if (or (eq AcModelSpace (vla-get-ActiveSpace (set *doc (vla-get-ActiveDocument (vlax-get-acad-object) ) ) ) ) (eq :vlax-true (vla-get-MSpace (eval *doc))) ) (vla-get-ModelSpace (eval *doc)) (vla-get-PaperSpace (eval *doc)) ) ) ) (defun LM:Selectif ( foo str nest / e ) (while (progn (setq e (car ((if nest nentsel entsel) str))) (cond ( (eq 'ENAME (type e)) (if (not (foo e)) (princ "\n** Invalid Object Selected **")) ) ) ) ) e ) (defun LM:GetObjectID ( doc obj ) (if (eq "X64" (strcase (getenv "PROCESSOR_ARCHITECTURE"))) (vlax-invoke-method (vla-get-Utility doc) 'GetObjectIdString obj :vlax-false) (itoa (vla-get-Objectid obj)) ) ) (defun LM:ss->vla ( ss ) (if ss ( (lambda ( i / e l ) (while (setq e (ssname ss (setq i (1+ i)))) (setq l (cons (vlax-ename->vla-object e) l)) ) l ) -1 ) ) ) I would like to reduce the number operations , any help would be appreciated. Here's the result I would like to have Exemple dwg Cablage VDI 3.dwg Thank you in advance (sorry for my English ) Cablage VDI 2.dwg Edited December 30, 2014 by tamariz Quote
hmsilva Posted December 30, 2014 Posted December 30, 2014 Hello tamariz, and welcome to CADTutor! If possible post a sample dwg with a few polylines and a few blocks to process. Henrique Quote
tamariz Posted December 30, 2014 Author Posted December 30, 2014 Thanks! I added dwg for example in my previous post Quote
hmsilva Posted December 30, 2014 Posted December 30, 2014 Select the magenta LwPolylines... (vl-load-com) (defun c:demo (/ attlst blk doc en_pt obj ss ss1 ss2 st_pt) (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) (if (setq ss (ssget '((0 . "LWPOLYLINE")))) (repeat (setq i (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i)))) st_pt (vlax-curve-getStartPoint obj) en_pt (vlax-curve-getEndPoint obj) ) (command "_.zoom" "_C" st_pt "") (setq ss1 (ssget "_C" (polar st_pt (* 0.25 pi) 0.1) (polar st_pt (* 1.25 pi) 0.1) '((0 . "INSERT") (2 . "RJ45CAT6") (66 . 1)) ) ) (command "_.zoom" "_C" en_pt "") (setq ss2 (ssget "_C" (polar en_pt (* 0.25 pi) 0.1) (polar en_pt (* 1.25 pi) 0.1) '((0 . "INSERT") (2 . "RJ45CAT6") (66 . 1)) ) ) (cond (ss1 (setq blk (vlax-ename->vla-object (ssname ss1 0))) ) (ss2 (setq blk (vlax-ename->vla-object (ssname ss2 0))) ) ) (if blk (progn (setq attlst (vlax-invoke blk 'GetAttributes)) (foreach a attlst (if (= (vla-get-TagString a) "LENGTH") (vla-put-TextString a (strcat "%<\\AcObjProp Object(%<\\_ObjId " (LM:GetObjectID doc obj) ">%).Length \\f \"%lu6\">%" ) ) ) ) ) ) ) ) (vla-regen doc AcActiveViewport) (princ) ) (defun LM:GetObjectID (doc obj) (if (eq "X64" (strcase (getenv "PROCESSOR_ARCHITECTURE"))) (vlax-invoke-method (vla-get-Utility doc) 'GetObjectIdString obj :vlax-false ) (itoa (vla-get-Objectid obj)) ) ) Henrique Quote
tamariz Posted December 30, 2014 Author Posted December 30, 2014 The lisp works fine I just added 2 commands because I have a project where my UCS is different of World (vl-load-com) (defun c:demo (/ attlst blk doc en_pt obj ss ss1 ss2 st_pt) (command "_.ucs" "_world") (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) (if (setq ss (ssget '((0 . "LWPOLYLINE")))) (repeat (setq i (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i)))) st_pt (vlax-curve-getStartPoint obj) en_pt (vlax-curve-getEndPoint obj) ) (command "_.zoom" "_C" st_pt "") (setq ss1 (ssget "_C" (polar st_pt (* 0.25 pi) 0.1) (polar st_pt (* 1.25 pi) 0.1) '((0 . "INSERT") (2 . "etiquetteVDI") (66 . 1)) ) ) (command "_.zoom" "_C" en_pt "") (setq ss2 (ssget "_C" (polar en_pt (* 0.25 pi) 0.1) (polar en_pt (* 1.25 pi) 0.1) '((0 . "INSERT") (2 . "etiquetteVDI") (66 . 1)) ) ) (cond (ss1 (setq blk (vlax-ename->vla-object (ssname ss1 0))) ) (ss2 (setq blk (vlax-ename->vla-object (ssname ss2 0))) ) ) (if blk (progn (setq attlst (vlax-invoke blk 'GetAttributes)) (foreach a attlst (if (= (vla-get-TagString a) "LONGUEUR") (vla-put-TextString a (strcat "%<\\AcObjProp Object(%<\\_ObjId " (LM:GetObjectID doc obj) ">%).Length \\f \"%lu6\">%" ) ) ) ) ) ) ) ) (command "UCS" "P") (vla-regen doc AcActiveViewport) (princ) ) (defun LM:GetObjectID (doc obj) (if (eq "X64" (strcase (getenv "PROCESSOR_ARCHITECTURE"))) (vlax-invoke-method (vla-get-Utility doc) 'GetObjectIdString obj :vlax-false ) (itoa (vla-get-Objectid obj)) ) ) Quote
Tharwat Posted December 30, 2014 Posted December 30, 2014 Just wonder , why you are asking for a program since that you have one as shown in your video in the first post ! Quote
tamariz Posted December 30, 2014 Author Posted December 30, 2014 (edited) Just wonder , why you are asking for a program since that you have one as shown in your video in the first post ! it's just a video editing, I cut the sequence where I populates (manually) the fields it was to add more understanding to my request (my english is poor) Edited December 30, 2014 by tamariz Quote
tamariz Posted December 30, 2014 Author Posted December 30, 2014 one more question : how to modify the lisp to replace fields with simple texts ? I'm writing a lisp with 2 choices (field and text) Quote
hmsilva Posted December 30, 2014 Posted December 30, 2014 (edited) Perhaps something like this (vl-load-com) (defun c:demo (/ ans attlst blk doc en_pt obj ss ss1 ss2 st_pt) (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) (if (and (setq ss (ssget '((0 . "LWPOLYLINE")))) (not (initget 1 "Attribute Text")) (setq ans (getkword "\nEnter an option [Attribute/Text]: ")) ) (repeat (setq i (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i)))) str (rtos (vla-get-Length obj) 2 2) st_pt (trans (vlax-curve-getStartPoint obj) 0 1) en_pt (trans (vlax-curve-getEndPoint obj) 0 1) ) (command "_.zoom" "_C" st_pt "") (setq ss1 (ssget "_C" (polar st_pt (* 0.25 pi) 0.1) (polar st_pt (* 1.25 pi) 0.1) '((0 . "INSERT") (2 . "etiquetteVDI") (66 . 1) ) ) ) (command "_.zoom" "_C" en_pt "") (setq ss2 (ssget "_C" (polar en_pt (* 0.25 pi) 0.1) (polar en_pt (* 1.25 pi) 0.1) '((0 . "INSERT") (2 . "etiquetteVDI") (66 . 1) ) ) ) (cond (ss1 (setq blk (vlax-ename->vla-object (ssname ss1 0))) ) (ss2 (setq blk (vlax-ename->vla-object (ssname ss2 0))) ) ) (if blk (progn (setq attlst (vlax-invoke blk 'GetAttributes)) (foreach a attlst (if (= (vla-get-TagString a) "LENGTH") (vla-put-TextString a (if (= ans "Attribute") (strcat "%<[url="file://\\AcObjProp"]\\AcObjProp[/url] Object(%<[url="file://\\_ObjId"]\\_ObjId[/url] " (LM:GetObjectID doc obj) ">%).Length [url="file://\\f"]\\f[/url] \"%lu6\">%" ) str ) ) ) ) ) ) ) ) (vla-regen doc AcActiveViewport) (princ) ) (defun LM:GetObjectID (doc obj) (if (eq "X64" (strcase (getenv "PROCESSOR_ARCHITECTURE"))) (vlax-invoke-method (vla-get-Utility doc) 'GetObjectIdString obj :vlax-false ) (itoa (vla-get-Objectid obj)) ) ) Henrique Edited December 30, 2014 by hmsilva Code fixed Quote
tamariz Posted December 30, 2014 Author Posted December 30, 2014 Thanks, I have an error error: too many arguments: (IF (AND (SETQ SS (SSGET (QUOTE ((0 . "LWPOLYLINE"))))) (NOT (INITGET 1 "Attribute Text")) (SETQ ANS (GETKWORD "\nEnter an option [Attribute/Text]: "))) (REPEAT (SETQ I (SSLENGTH SS)) (SETQ OBJ (vlax-ename->vla-object (SSNAME SS (SETQ I (1- I)))) STR (RTOS (vla-get-Length OBJ) 2 2) ST_PT (TRANS (vlax-curve-getStartPoint OBJ) 0 1) EN_PT (TRANS (vlax-curve-getEndPoint OBJ) 0 1)) (COMMAND "_.zoom" "_C" ST_PT "") (SETQ SS1 (SSGET "_C" (POLAR ST_PT (* 0.25 PI) 0.1) (POLAR ST_PT (* 1.25 PI) 0.1) (QUOTE ((0 . "INSERT") (2 . "etiquetteVDI"))) (66 . 1)))) (COMMAND "_.zoom" "_C" EN_PT "") (SETQ SS2 (SSGET "_C" (POLAR EN_PT (* 0.25 PI) 0.1) (POLAR EN_PT (* 1.25 PI) 0.1) (QUOTE ((0 . "INSERT") (2 . "etiquetteVDI"))) (66 . 1)))) I will try to look at it Quote
hmsilva Posted December 30, 2014 Posted December 30, 2014 Thanks,I have an error error: too many arguments: ... Sorry, my bad... Code in msg#10 already reviewed. Should work in WCS or UCS. Henrique Quote
hmsilva Posted December 30, 2014 Posted December 30, 2014 Nice job ! Glad I could help Henrique Quote
tamariz Posted December 31, 2014 Author Posted December 31, 2014 (edited) I finish my lisp but i have a problem (an error) I would like replace the block name by the entity name of the previous block selection in this filter (if my blockname is different of "etiquetteVDI") But it is possible? ('(0 . "INSERT") (cons -2 dxf_cod) '(66 . 1) ) definition of the value "dxf_cod" (setq dxf_cod (entget (ssname js 0))) Here ensemble lisp code FIXED (defun l-coor2l-pt (lst flag / ) (if lst (cons (list (car lst) (cadr lst) (if flag (+ (if (vlax-property-available-p ename 'Elevation) (vlax-get ename 'Elevation) 0.0) (caddr lst)) (if (vlax-property-available-p ename 'Elevation) (vlax-get ename 'Elevation) 0.0) ) ) (l-coor2l-pt (if flag (cdddr lst) (cddr lst)) flag) ) ) ) (defun c:CABLECDC2 ( / js dxf_cod mod_sel n lremov ename l_pt l_pr key js_cl obj_vlax pr lst_pt pt pt_cl e ans attlst blk doc en_pt obj ss ss1 ss2 st_pt) (setq e (entsel "\nFilter Selection by Entity name: ")) (if e (setq js (ssget "_X" (list(cons 2 (cdr (assoc 2 (entget (car e)))))(cons 0 "INSERT"))))) (vl-load-com) (setq dxf_cod (entget (ssname js 0))) (foreach m (foreach n dxf_cod (if (not (member (car n) '(0 2 ))) (setq lremov (cons (car n) lremov)))) (setq dxf_cod (vl-remove (assoc m dxf_cod) dxf_cod)) ) (initget "Unique Tout Manuel _Single All Manual") (if (eq (setq mod_sel (getkword "\nMode de sélection filtrée, choix [unique/Tout/Manuel]<Manuel>: ")) "Single") (setq n -1) (if (eq mod_sel "All") (setq js (ssget "_X" dxf_cod) n -1) (setq js (ssget dxf_cod) n -1) ) ) (repeat (sslength js) (setq ename (vlax-ename->vla-object (ssname js (setq n (1+ n))))) (setq l_pr (list 'StartPoint 'EndPoint 'Center 'InsertionPoint 'Coordinates 'FitPoints)) (foreach n l_pr (if (vlax-property-available-p ename n) (setq l_pt (if (or (eq n 'Coordinates) (eq n 'FitPoints)) (append (if (eq (vla-get-ObjectName ename) "AcDbPolyline") (l-coor2l-pt (vlax-get ename n) nil) (if (and (eq n 'FitPoints) (zerop (vlax-get ename 'FitTolerance))) (l-coor2l-pt (vlax-get ename 'ControlPoints) T) (l-coor2l-pt (vlax-get ename n) T) ) ) l_pt ) (cons (vlax-get ename n) l_pt) ) ) ) ) ) (cond (l_pt (while (and (setq key (grread T 4 0)) (/= (car key) 3)) (redraw) (cond ((eq (car key) 5) (foreach n l_pt (grdraw (trans n 0 1) (cadr key) 3) ) ) ) ) (if (eq (car key) 3) (progn (princ "\nSelect polyline (cable tray): ") (while (not (setq js_cl (ssget "_+.:E:S" '((0 . "LWPOLYLINE")))))) (setq obj_vlax (vlax-ename->vla-object (ssname js_cl 0)) pr -1 lst_pt nil) (repeat (if (zerop (vlax-get obj_vlax 'Closed)) (1+ (fix (vlax-curve-getEndParam obj_vlax))) (fix (vlax-curve-getEndParam obj_vlax))) (setq pt (vlax-curve-GetPointAtParam obj_vlax (setq pr (1+ pr))) lst_pt (cons pt lst_pt) ) ) (if (< (distance (car lst_pt) (trans (cadr key) 1 0)) (distance (last lst_pt) (trans (cadr key) 1 0))) (setq lst_pt (reverse lst_pt)) ) (foreach n l_pt (setq pt_cl (vlax-curve-getClosestPointTo obj_vlax n)) (command "_.pline" "_none" (trans n 0 1) "_none" (trans pt_cl 0 1)) (foreach el lst_pt (if (<= (distance el (trans (cadr key) 1 0)) (distance pt_cl (trans (cadr key) 1 0))) (command "_none" (trans el 0 1)) ) ) (command "_none" (cadr key) "") ) ) ) (redraw) ) ) (vl-load-com) (command "_.ucs" "_world") (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) (if (and (setq ss (ssget '((0 . "LWPOLYLINE")))) (not (initget 1 "Attribute Text")) (setq ans (getkword "\nEnter an option [Attribute/Text]: ")) ) (repeat (setq i (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i)))) str (rtos (vla-get-Length obj) 2 2) st_pt (trans (vlax-curve-getStartPoint obj) 0 1) en_pt (trans (vlax-curve-getEndPoint obj) 0 1) ) (command "_.zoom" "_C" st_pt "") (setq ss1 (ssget "_C" (polar st_pt (* 0.25 pi) 0.1) (polar st_pt (* 1.25 pi) 0.1) (list '(0 . "INSERT") (assoc 2 dxf_cod) '(66 . 1)) ) ) (command "_.zoom" "_C" en_pt "") (setq ss2 (ssget "_C" (polar en_pt (* 0.25 pi) 0.1) (polar en_pt (* 1.25 pi) 0.1) (list '(0 . "INSERT") (assoc 2 dxf_cod) '(66 . 1)) ) ) (cond (ss1 (setq blk (vlax-ename->vla-object (ssname ss1 0))) ) (ss2 (setq blk (vlax-ename->vla-object (ssname ss2 0))) ) ) (if blk (progn (setq attlst (vlax-invoke blk 'GetAttributes)) (foreach a attlst (if (= (vla-get-TagString a) "LENGTH") (vla-put-TextString a (if (= ans "Attribute") (strcat "%<\\AcObjProp Object(%<\\_ObjId " (LM:GetObjectID doc obj) ">%).Length \\f \"%lu6\">%" ) str ) ) ) ) ) ) ) ) (command "UCS" "P") (vla-regen doc AcActiveViewport) (princ) ) (defun LM:GetObjectID (doc obj) (if (eq "X64" (strcase (getenv "PROCESSOR_ARCHITECTURE"))) (vlax-invoke-method (vla-get-Utility doc) 'GetObjectIdString obj :vlax-false ) (itoa (vla-get-Objectid obj)) ) ) Edited January 1, 2015 by tamariz Code fixed Quote
hmsilva Posted December 31, 2014 Posted December 31, 2014 Hi tamariz, if your block is not dynamic, (cons 2 dxf_cod) will do the trick. Henrique Quote
tamariz Posted January 1, 2015 Author Posted January 1, 2015 Hi tamariz, if your block is not dynamic, (cons 2 dxf_cod) will do the trick. Henrique I try this, but i have an error: bad function: (0 . "INSERT") I think the code 2 is for a Blockname but (setq dxf_cod (entget (ssname js 0))) return an entity name? Any idea? My block is not dynamic. Happy New Year and good health to all Quote
hmsilva Posted January 1, 2015 Posted January 1, 2015 (edited) Try (list '(0 . "INSERT") (assoc 2 dxf_cod) '(66 . 1)) EDIT: ename is unique, with the entity name you don't need to select, just change the atribute... (I'm don't understand what you are trying to do) EDIT 1:with (setq dxf_cod (entget (ssname js 0))) you'll get a list with all the entity definition data, with (cdr (assoc -1 dxf_cod)) you'll get the entity name... HTH Henrique Edited January 1, 2015 by hmsilva Quote
tamariz Posted January 1, 2015 Author Posted January 1, 2015 Try (list '(0 . "INSERT") (assoc 2 dxf_cod) '(66 . 1)) Works fine ! EDIT: ename is unique, with the entity name you don't need to select, just change the atribute... (I'm don't understand what you are trying to do) EDIT 1:with (setq dxf_cod (entget (ssname js 0))) you'll get a list with all the entity definition data, with (cdr (assoc -1 dxf_cod)) you'll get the entity name... HTH Henrique thank you for this information and your patience I am a beginner and this is my first lisp I fixed the code in my previous post http://www.cadtutor.net/forum/showthread.php?90252-Extract-polyline-length-to-Attributes-(field)&p=617951&viewfull=1#post617951 Quote
hmsilva Posted January 1, 2015 Posted January 1, 2015 Works fine !thank you for this information and your patience I am a beginner and this is my first lisp I fixed the code in my previous post http://www.cadtutor.net/forum/showthread.php?90252-Extract-polyline-length-to-Attributes-(field)&p=617951&viewfull=1#post617951 You're welcome, tamariz! Glad you got a solution! We all had to write our first code... Henrique Quote
