Batch Plot only plotting out 2D Wireframe
I have 100+ DWG files that I need to print. The viewports are set to plot "Legacy Hidden" and page setup is set to plot to PDF. When I plot them indivudually they plot correctly, but when I try to use sheet set manager or the batch plot utility, the viewports only plot as 2D wireframe.
I tried both AutoCAD 2014 and AutoCAD 2015 and get the same result.
Can anyone suggest a solution or a different tool I could use to plot large quantities of DWG files?
Just to be clear, when you batch plot you are specifying the same pagesetup and not using the built-in plot to pdf?
Here are a few screen shots showing the settings I'm trying to use. In the Page Setup you can see it's set to Shade plot "Legacy Hidden" which matches my viewport's shade plot setting.
