Hi
Stupid question I know, but how do you copy from one drawing with a base point into another drawing.
There used to be an option on the right click menu but it's not there any more.
Thank you
That was SO easy ! - thank you - apologies for the stupid question
You can also type "copy" and hit enter. You will be prompted to select your object(s). Right click when you are done selecting and then you are prompted to select a base point.
"the only stupid question is the one you are afraid to ask"
an instructor i once had
Hi
It's still there, they just buried it in the Clipboard submenu (COPYBASE is the command name if you ever feel the need to type it out ;) )
Thank you everyone ! Much appreciated !!:)
