GemmaEBaird Posted January 11, 2015 Posted January 11, 2015 Afternoon Is there such a thing as a block library like in sketchup - just something with generic 3D trees / chairs / people ?? Thank you in advance. Quote
nestly Posted January 11, 2015 Posted January 11, 2015 "Explore Sample Drawings" on the NewTab. The blocks are stored within the sample drawings and IMO are best accessed through Design Center (type DC at the command line then navigate to the location of the sample drawings) Quote
GemmaEBaird Posted January 11, 2015 Author Posted January 11, 2015 Thank you - which sample drawing would you recommend for 3d basics ? Quote
nestly Posted January 11, 2015 Posted January 11, 2015 Whoops... I missed the "3D" part I don't think AutoCAD includes any 3D blocks, and doesn't even offer a decent library online. Quote
GemmaEBaird Posted January 11, 2015 Author Posted January 11, 2015 Any ide where I could get some free ones? Quote
Cad64 Posted January 11, 2015 Posted January 11, 2015 If you have the pro version of sketchup you can export sketchup models to dwg format to use in Autocad. Or you can use the Sketchup Import app which is available at the app store. It's free and it will let you import Sketchup models directly into Autocad: https://apps.exchange.autodesk.com/ACD/en/Detail/Index?id=appstore.exchange.autodesk.com%3Asketchupimportforautocad2014%3Aen Quote
mikekmx Posted January 11, 2015 Posted January 11, 2015 Afternoon Is there such a thing as a block library like in sketchup - just something with generic 3D trees / chairs / people ?? Thank you in advance. yer, you'd think for £3-4k they'd have a decent library of blocks. happy days. Quote
BIGAL Posted January 12, 2015 Posted January 12, 2015 There is a lot of stuff out there you just have to look for it unfortunatley, some is free some at a price. Just google 1 item at a time "3d trees Autocad free" Quote
JamCAD Posted January 12, 2015 Posted January 12, 2015 I would suggest you google 'free 3d AutoCAD blocks'. Or you could head straight to http://www.turbosquid.com they have the largest quality 3d block library, both free and paid, that I know of. Just keep in mind that they are not all in the AutoCAD dwg format, you could however convert most of the other formats into dwg. Just be aware some free blocks may have copyright conditions that prevent commercial use, make sure you respect any copyright requirements. Quote
JamCAD Posted January 12, 2015 Posted January 12, 2015 Here's what I came up with after less than 5 minutes searching on google. http://www.bibliocad.com/library/trees-and-plants/trees--3d/1 http://www.cadblocksfree.com/index.php?id=122 http://www.bibliocad.com/library/people/3d/1 http://www.cadforum.cz/catalog_en/?cat=14 http://www.hermanmiller.com.au/design-resources/3d-models-revit/3d-models-by-product/seating/performance-work-chairs.html Quote
Cad64 Posted January 12, 2015 Posted January 12, 2015 And remember, models don't have to be in .dwg format only. AutoCAD can import a variety of different formats. Just run the IMPORT command and check out the "Files of Type" list. Quote
