Open gable roof on a house that has equal sides, how to do it?
Hi,
I am using Autocad Architecture to make this drawing and I want to use command roof to make my roof (of course). The house I drew has wall dimension 10 x 10 meters. When I draw the roof with the roof command I get a pyramid hip roof. I know that in order to change from “pyramid hip roof” to “open gable roof” I need to pull the blue handle on the top. Unfortunately there is only one blue handle to pull. This is because the house has equal sides but there must be a way to make an open gable roof, on this house right?
Thanks in advance.
Miro
As you create your roof read the command line to get the GABLE prompt option - this will let you tell it which edges of the roof need to be gables and which don't.
dJE
dJE
Yes, I did as you said and it worked out just fine. Thank you
Glad it worked for you, Miro, happy to have helped :)
dJE
