Change Text Style for Layer??
Is there a way to change the text style for an entire layer with out having to highlight everything?
Try this without isolating layers per drawing(s) 'style' will suffice current text setting and configurations. Let me know if this works.
Another option is to select one piece of text, right click, and hit "Select Similar." That gives you all the text on that layer, and you can change the style for all of them in the Properties window. Remember that you may have to do the same thing with mtext; for some reason you can't do both at once.
If you don't have the Select similar option, try Express tools' Getsel command.
