HELP: Transfer autocad settings from office PC to home PC.
My office PC which i work on has all my customization eg, Toolbar scripts,Tool pallet scripts, system variable, command variable etc.....
Can i just copy the whole "support" folder (as indicated below) from the office PC over to my home PC in the same "support" folder?
All my setting will be the same?
........AppData\Roaming\Autodesk\AutoCAD 2014\R19.1\enu\support
If not, which folder can i copy from?
Thanks
Search for a file called 'Acad.cuix'. This should hold your workspace settings, toolbar locations etc. Take it home and replace the same file on your PC, but make a backup copy of the existing 'Acad.cuix' first.
However, I've recently done this and all my customised icons showed the wrong icon or just blank icons, but the commands were in place. I made a thread about it, but no one could actually resolve it... http://www.cadtutor.net/forum/showthread.php?89707
In the end I had to make a note of all my cutomisations and set them up manually on the 2nd PC. Perhaps you will have better luck.
Thanks for the help guys. Was on vacation hence the late reply. Will go through them.
