Shoey Posted January 15, 2015 Posted January 15, 2015 Hi all I would like to know if there is a way similar to the XLIST command to display and list the layer properties of Xrefs but these Xrefs I would like to XLIST are attached Xrefs to the Parent Xref. As far as I know, XLIST in AutoCAD only lists the Parent layer properties. It does not dig deeper to nested Xrefs. I presume a lisp would do this? If anyone knows of one and willing to share, that would be appreciated. Many Thanks Quote
Lee Mac Posted January 15, 2015 Posted January 15, 2015 Very quickly written, but may help: (defun c:laylist ( / ent ind sel ) (setq ind 0) (if (setq sel (nentselp)) (foreach ent (reverse (cons (car sel) (cadddr sel))) (princ "\n") (repeat ind (princ " ")) (if (< 0 ind)(princ "|\n")) (repeat ind (princ " ")) (princ "+--+ ") (princ (cdr (assoc 8 (entget ent)))) (setq ind (1+ ind)) ) ) (princ) ) Quote
Shoey Posted January 15, 2015 Author Posted January 15, 2015 Lee - Not for the first time, thanks. Appreciate your time in replying to my question. Shoey Quote
Lee Mac Posted January 15, 2015 Posted January 15, 2015 You're welcome Shoey - the program could obviously be expanded extensively to list additional properties. Quote
