resullins Posted January 16, 2015 Posted January 16, 2015 Ok... I think I may have a corrupt file. I was working yesterday on a background file, and attached it to my working file. The background file was quite large due to just a lot of geometry, but I got it down as small as I could (about 2.5 M). It still seemed a little odd that it was so large. I purged all the things! Ran Overkill, nothing was really helping. So I gave up and just used it as large as it was. So today, I open the working file, and the background file in question is now an unresolved xref. I opened it, audited it, and after having it get stuck for a good 20 minutes, it fixed 4 items. I tried to re-attach it, and it's giving me INVALID in the command line and telling me to recover. I run RECOVER, and it's been sitting here forever! It's stuck on "Pass 1 95200 objects audited" Should I just scrap this POS? Or is there some trick I have yet to try. Also, I would attach this file, but like I said, it's large and in charge. Quote
resullins Posted January 16, 2015 Author Posted January 16, 2015 Ok... update. So RECOVER didn't fix the problem. Quote
steven-g Posted January 16, 2015 Posted January 16, 2015 is there a *.bak file that you could maybe rename and use, or possibly a recovery file in the temp folder. Quote
RobDraw Posted January 17, 2015 Posted January 17, 2015 If you could post the original file to dropbox or something similar, others can test the it for you. Otherwise it's a guessing game. Quote
resullins Posted January 19, 2015 Author Posted January 19, 2015 Ok, sorry for the late reply... I had a pool tournament over the weekend. @steven-g: no, the .dwg was emailed to me, and the people that sent it to me didn't alter it at all for the reason I'm describing, but that made their drawings unreadable. I have to make installation drawings, they need to be readable. And I don't have access to the architect to ask for a new one. @RobDraw: Good idea. Ok... here's the link. https://www.dropbox.com/sh/uarok9uyv6jxtl5/AAA_mFzoqZJy0eD2qnBXIM_-a?dl=0 Quote
Bogbadbob658 Posted January 20, 2015 Posted January 20, 2015 I ran recover on the file and it picked up 5 errors. I also purged it (before I ran recover). It hasn't made much difference to the file size. It take about 20 minutes to recover it. I xref'd it into one of my drawings before and after I recovered it and didn't get any problems. Here is the link of the recovered model. https://www.dropbox.com/s/m8e3w0fxgng5q79/SD2_FLOOR_XREF_temp.dwg?dl=0 Quote
Cad64 Posted January 20, 2015 Posted January 20, 2015 Try running WBLOCK and save the drawing entities out to a new file. A coworker was just having similar problems with one of her files. I Wblocked it out to a new file and the file size dropped from 3mb down to 400kb. Quote
steven-g Posted January 21, 2015 Posted January 21, 2015 -purge with the option regapps, reduced the file from 4.6 MB to 1.3 MB and removed 124 000 registered applications, followed by a normal purge reduced the file down to 800 KB. Quote
Dadgad Posted January 21, 2015 Posted January 21, 2015 -purge with the option regapps, reduced the file from 4.6 MB to 1.3 MB and removed 124 000 registered applications, followed by a normal purge reduced the file down to 800 KB. 124,000 registered apps? That is getting up into record territory there! Did you AUDIT it too? Quote
steven-g Posted January 21, 2015 Posted January 21, 2015 Yeah audit purge -purge (with regapps) wblock and a few others, but it was the regapps that gave the most difference. Quote
