Multiple Text Manipulation
Hi guys i have received drawings that need cleaning up and fixing , problem is the text has been manipulated in such a away that i have to edit each text individually to get the result i need.
might there be a lisp routine i could run to fix this situation , this is just one of probably 160 odd drawing that needs repair.
i have attached an example.
font.dwg
Without looking at your drawing, I'm assuming that someone has overridden the formatting within MText. Look for a LISP called STPMText or StripMtext. I believe they are both posted here somewhere and both work a treat.
you are correct Sir. i have found Stripmtext v5 for some strange reason it does not fix all the the text. ot has fised most of it but some stay unchanged. ill search for STPMText.
you are to kind thank you.
