Luancat Posted January 19, 2015 Posted January 19, 2015 Hi! I have two routines: ; UPTRIM ; ROTINA PARA TRAÇAR LINHA DE CORTE E EXECUTAR COMANDO TRIM ; FEITA POR L.A.CAETANO ;___________________________________________________________________________ (defun c:Uptrim(/ LAYCOR pt1 pt2) (setq LAYCOR (getvar "clayer")) ;Guarda o layer corrente. (command "_.ortho" "_off") ;Desliga o modo ortho. (setq pt1 (getpoint "\nPrimeiro ponto : ")) ;Início da linha de corte. (setq pt2 (getpoint "\nSegundo ponto : ")) ;final da linha de corte. (command "-layer" "S" "CONST" "") ;Torna o layer Const corrente. (command "_line" pt1 pt2 "") ;Traça a linha de corte (command "_TRIM" "@0,0" "" Pause"") ;Ativa o comando trim e seleciona a linha de corte. (setvar "clayer" LAYCOR) ;Retorna ao layer original. (command "_erase" "P" "") ;Apaga a linha de corte. (princ) ) (princ) ; UPEXTEN ; ROTINA PARA TRAÇAR LINHA DE CORTE E EXECUTAR COMANDO EXTEND ; FEITA POR L.A.CAETANO ;___________________________________________________________________________ ;*************************************************************************** (defun c:Upexten(/ LAYCOR pt1 pt2) (setq LAYCOR (getvar "clayer")) ;Guarda o layer corrente. (command "_.ortho" "_off") ;Desliga o modo ortho. (setq pt1 (getpoint "\nPrimeiro ponto : ")) ;Início da linha de corte. (setq pt2 (getpoint "\nSegundo ponto : ")) ;final da linha de corte. (command "-layer" "S" "CONST" "") ;Torna o layer Const corrente. (command "_line" pt1 pt2 "") ;Traça a linha de corte (command "_EXTEND" "@0,0" "" Pause"") ;Ativa o comando Extend e seleciona a linha de corte. (setvar "clayer" LAYCOR) ;Retorna ao layer original. (command "_erase" "P" "")) ;Apaga a linha de corte. (princ) ) (princ) The first one, automaticaly loads with each drawing I open. The second doesn't, I have to load it manualy. I did the same procedures for both. Without discussing the structure of the two, because they work normally after loaded, someone can tell me why this happens? Quote
hmsilva Posted January 20, 2015 Posted January 20, 2015 (edited) Hi Luancat, could you please, explain to us what are 'the same procedures for both'... The second routine, have an extra )) ;Apaga a linha de corte. Henrique Edited January 20, 2015 by hmsilva typo Quote
Spaj Posted January 20, 2015 Posted January 20, 2015 Hi Lisps will only load automatically if you have specifically set AutoCAD to do so. Check the following link to see if only one routine has been added http://www.lee-mac.com/autoloading.html Quote
Luancat Posted January 20, 2015 Author Posted January 20, 2015 Hi guys! I think it will answer both of You. The same procedures means what Spaj told me to do. I,ve done everything stated in the link: Startup suite, Acaddoc, folders in the trust location... My lisp, is in: Appdata/Roaming/Autodesk/AutoCad 2014........./Suport and there is a copy of all in the ApplicationsPlugins folder even the Acaddoc.lsp. I'll pass through it all again and see if I didin't miss something (I've done already but..knows...) I'll tell you after. Thank you both. Quote
hmsilva Posted January 20, 2015 Posted January 20, 2015 The second routine, have an extra )) ;Apaga a linha de corte. Hi Luancat, did you read all my previous post? The second code, have an extra right paren, you'll have to remove the red paren... Henrique Quote
Luancat Posted January 20, 2015 Author Posted January 20, 2015 Hi, again! Its odd, after I've done a new acaddoc others programs doesn't load. Can you see if there is something wrong with that, please. ; ACAD.LSP ; ACAD.LSP Version 1.0 for Autocad 2012 ; ; (autoload "lica" '("lica")) (autoload "lican" '("lican")) (autoload "licang" '("licang")) (autoload "lichor" '("lichor")) (autoload "lichor2" '("lichor2")) (autoload "lichor3" '("lichor3")) (autoload "licofs" '("licofs")) (autoload "licofs2" '("licofs2")) (autoload "licofs3" '("licofs3")) (autoload "licper" '("licper")) (autoload "licper2" '("licper2")) (autoload "licper3" '("licper3")) (autoload "licver" '("licver")) (autoload "licver2" '("licver2")) (autoload "licver3" '("licver3")) (autoload "R90" '("R90")) (autoload "R91" '("R91")) (autoload "Retrim" '("Retrim")) (autoload "RETRIMex" '("Retrimex")) (autoload "Uptrim" '("Uptrim")) (autoload "MACROS") (autoload "Upexten" '("Upexten")) (autoload "PW" '("PW")) (autoload "ZeraZ" '("zz"))) ;; ;; silent load. It is stored in the support folder. "Obrigado" Quote
Luancat Posted January 20, 2015 Author Posted January 20, 2015 Hi, hmsilva, I've read and did it before my last reply. thanks Quote
hmsilva Posted January 20, 2015 Posted January 20, 2015 (edited) If copy/paste at command line (findfile "acaddoc.lsp") the returned path is from your acaddoc.lsp file, or other? EDIT: Luancat, your file header says 'ACAD.LSP', but your file is 'acaddoc.lsp', correct? AutoCAD will search for a file, at the 'Support Search Path' and current directory, and loads the first found file. In my acaddoc.lsp, paths are hardcoded, to avoid AutoCAD load the first found file with the same name, please note, if the file extension is omitted, AutoCAD will load the first found file with the same name, and a .lsp, .fas or .vlx as extension... e.g. (autoload "X:/MyLisp/Objects.LSP" '("hio" "uniso" "iso")) (autoload "X:/MyLisp/Occ.LSP" '("occ")) Henrique Edited January 20, 2015 by hmsilva Quote
Luancat Posted January 22, 2015 Author Posted January 22, 2015 Hi, That thing about file header, I thought it was irrelevant due to the semicolon but I already fixed it. Let me ask you about something. I have to store the acaddoc.lsp in the Aplicationplugins folder or it must be only in one folder like support? I'll try to do like you sad about the paths, let's se what happens. Thank'u Quote
hmsilva Posted January 22, 2015 Posted January 22, 2015 That thing about file header, I thought it was irrelevant due to the semicolon but I already fixed it. You are correct, it's irrelevant, my doubt was if it was just the header or the filename... I have to store the acaddoc.lsp in the Aplicationplugins folder or it must be only in one folder like support? Store in support, and test with findfile if is that one the file AutoCAD first find. Henrique Quote
Luancat Posted January 22, 2015 Author Posted January 22, 2015 I've done that and its fine. The fille in the support is the first. Ok, everthung is done and iven so the same lisps doen't load automatically. I've made a routine that load the funtions I need and put in a button everytime I need them I push the button and it works. I''ll fo on like that until I found what's wrong. Thank you all guys. Your attention help me much despite that issue but it make me learn much. Quote
hmsilva Posted January 22, 2015 Posted January 22, 2015 You're welcome, Luancat! If necessary, and easier for you, you may PM me in Portugês... Henrique Quote
