Guest Posted January 22, 2015 Posted January 22, 2015 (edited) Hi i need help with a cross section lisp. I use *.txt files with distanse and elevetion to draw the polyline for the ground. I need help to do 2 things 1) draw the table under this polyline with the distanse and the elevetions 2) to add an opltion if i have 2 ground to add Here is my code to modify.For more details look the example.dwg file and two ground files to do the test. (Defun c:test () (setq g1 (getfiled "select ground1 file L,H (*.txt)" "" "txt" 16)) (setq fil (open g1 "r")) (COMMAND "_layer" "_m" "ground1" "_c" "94" "" "") (COMMAND "_layer" "_m" "line" "_c" "9" "" "") ; The line must be dashdot (COMMAND "_layer" "_m" "section table" "_c" "7" "" "") (COMMAND "_layer" "_m" "Datum" "_c" "7" "" "") (setq scl(/ (getreal "\n give the scale (100,200,500,etc) : ") 100)) (setq ht(* 0.0018 scl)) ; text size (setq oflin (* 0.012 scl)) ; offset lines ;I dont know how to add a questio at the begining like this ;If you want to draw ground1 select A / for ground2 select B ;(progn ; (initget "A B") ; (setq ; k ; (cond ; ((getkword ; "\nFor ground1 (Α)/ For ground2 (Β) < A > :" ; ) ; ) ; ("A") ; ) ; ) ; ; from ground2 ; ;(setq g2 (getfiled "select ground2 file L,H (*.txt)" "" "txt" 16)) ;(setq fil (open g2 "r")) ;(COMMAND "_layer" "_m" "ground2" "_c" "10" "" "") ; ; (command "_.pline"); start Polyline (while (setq lin (read-line fil)) (command lin)); feed in coordinates (command ""); end Polyline (close fil) ; I dont know how to draw the lines );End Defun example.dwg ground1 and ground2.dwg ground1.txt ground2.txt Edited January 23, 2015 by prodromosm Quote
Guest Posted January 23, 2015 Posted January 23, 2015 (edited) Hi sanju2323 nice code but i need same chances 1) i use grads so i have problem with the texts rotation 2) change text size by scale 3)An option to choose ground1/ground2 4) in post #1 i ask to choose for ground 1 automaticaly the datum and for the ground 2 to geve manualy the datum 5)Add layer ground1 for ground 1 elevetion and distance and ground 2 for ground2 Thanks Edited January 23, 2015 by prodromosm Quote
Guest Posted January 23, 2015 Posted January 23, 2015 I try to change this but i have a text print problem (defun ERR (S) (if (= S "Function cancelled") (princ "\nVERTEXT - cancelled: ") (progn (princ "\nVERTEXT - Error: ") (princ S) (terpri)) ) (RESETTING) (princ "SYSTEM VARIABLES have been reset\n") (princ) ) (defun SETV (SYSTVAR NEWVAL) (setq X (read (strcat SYSTVAR "1"))) (set X (getvar SYSTVAR)) (setvar SYSTVAR NEWVAL) ) (defun SETTING () (setq OERR *ERROR*) (setq *ERROR* ERR) (SETV "CMDECHO" 0) (SETV "BLIPMODE" 0) ) (defun RSETV (SYSTVAR) (setq X (read (strcat SYSTVAR "1"))) (setvar SYSTVAR (eval X)) ) (defun RESETTING () (RSETV "CMDECHO") (RSETV "BLIPMODE") (setq *ERROR* OERR) ) (defun DXF (CODE ENAME) (cdr (assoc CODE (entget ENAME)))) ; dxf (defun VERTEXT (/ EN VLIST) (setq EN (GET-EN)) (if (= (DXF 0 EN) "LWPOLYLINE") (setq VLIST (GET-LWVLIST EN)) (setq VLIST (GET-PLVLIST EN)) ) (WRITE-IT VLIST EN) ) (defun GET-EN (/ NO-ENT EN MSG1 MSG2) (setq NO-ENT 1 EN NIL MSG1 "\nSelect a polyline: " MSG2 "\nNo polyline selected, try again." ) ; setq (while NO-ENT (setq EN (car (entsel MSG1))) (if (and EN (or (= (DXF 0 EN) "LWPOLYLINE") (= (DXF 0 EN) "POLYLINE")) ; or ) ; and (progn (setq NO-ENT NIL)) ; progn (prompt MSG2) ) ; if ) ; while EN ) ; get-en (defun GET-LWVLIST (EN / ELIST NUM-VERT VLIST) (setq ELIST (entget EN) NUM-VERT (cdr (assoc 90 ELIST)) ELIST (member (assoc 10 ELIST) ELIST) VLIST NIL ) ; setq (repeat NUM-VERT (setq VLIST (append VLIST (list (cdr (assoc 10 ELIST)))) ; append ) ; setq (setq ELIST (cdr ELIST) ELIST (member (assoc 10 ELIST) ELIST) ) ; setq ) ; repeat VLIST ) ; get-lwvlist (defun GET-PLVLIST (EN / VLIST) (setq VLIST NIL EN (entnext EN) ) ; setq (while (/= "SEQEND" (DXF 0 EN)) (setq VLIST (append VLIST (list (DXF 10 EN)))) (setq EN (entnext EN)) ) ; while VLIST ) ; get-plvlist (defun WRITE-IT (VLST EN / NEWVLIST MSG3 FNAME) (setq NEWVLIST (mapcar '(lambda (X) (trans X EN 0)) ;_ lambda VLST ) ;_ mapcar MSG3 "Polyline vertex file" ;FNAME (getfiled MSG3 "" "txt" 1) F1 (open "FNAME" "w") ) ; setq (WRITE-HEADER) (WRITE-VERTICES NEWVLIST) (setq F1 (close F1)) ) ;_ write-it (defun WRITE-HEADER (/ STR) (setq STR " POLYLINE VERTEX POINTS") (write-line STR F1) (setq STR (strcat " X " " Y " " Z") ;_ strcat ) ;_ setq (write-line STR F1) ) ;_ write-header (defun WRITE-VERTICES (NEWVLIST / XSTR YSTR ZSTR STR) [color="red"] (COMMAND "_layer" "_m" "ground1" "_c" "94" "" "") (setq scl(/ (getreal "\n give the scale (100,200,500,etc) : ") 100)) (setq httt (* 0.018 scl))[/color] (setq gptx (getpoint "\nBasepoint for X axis: ")) (setq gpty (getpoint "\nBasepoint for Y axis: ")) (foreach ITEM NEWVLIST (setq XSTR (rtos (nth 0 ITEM) 2 3) YSTR (rtos (nth 1 ITEM) 2 3) ZSTR (rtos (nth 2 ITEM) 2 3) STR (strcat XSTR (SPACES XSTR) YSTR (SPACES YSTR) ZSTR) ;_ strcat ) ; setq ; (write-line STR F1) (command "text" (list (+ (atof xstr) (/ (atof httt) 2.0)) (cadr gptx)) httt [color="red"] "0"[/color] (strcat xstr) ) (command "text" (list (+ (atof xstr) (/ (atof httt) 2.0)) (cadr gpty)) httt [color="red"] "0"[/color] (strcat ystr) ) ) ; foreach ) ; write-vertices (defun SPACES (STR / FIELD NUM CHAR SPACE) (setq FIELD 15 NUM (- FIELD (strlen STR)) CHAR " " SPACE "" ) ;_ setq (repeat NUM (setq SPACE (strcat SPACE CHAR))) ;_ repeat ) ;_ spaces (defun C:Test2 () (SETTING) (VERTEXT) (RESETTING) (princ)) ; c:nsl (prompt "\nEnter Test to start") Quote
Guest Posted January 23, 2015 Posted January 23, 2015 I update the code but i have a problem with the scale of the text (defun ERR (S) (if (= S "Function cancelled") (princ "\nVERTEXT - cancelled: ") (progn (princ "\nVERTEXT - Error: ") (princ S) (terpri)) ) (RESETTING) (princ "SYSTEM VARIABLES have been reset\n") (princ) ) (defun SETV (SYSTVAR NEWVAL) (setq X (read (strcat SYSTVAR "1"))) (set X (getvar SYSTVAR)) (setvar SYSTVAR NEWVAL) ) (defun SETTING () (setq OERR *ERROR*) (setq *ERROR* ERR) (SETV "CMDECHO" 0) (SETV "BLIPMODE" 0) ) (defun RSETV (SYSTVAR) (setq X (read (strcat SYSTVAR "1"))) (setvar SYSTVAR (eval X)) ) (defun RESETTING () (RSETV "CMDECHO") (RSETV "BLIPMODE") (setq *ERROR* OERR) ) (defun DXF (CODE ENAME) (cdr (assoc CODE (entget ENAME)))) ; dxf (defun VERTEXT (/ EN VLIST) (setq EN (GET-EN)) (if (= (DXF 0 EN) "LWPOLYLINE") (setq VLIST (GET-LWVLIST EN)) (setq VLIST (GET-PLVLIST EN)) ) (WRITE-IT VLIST EN) ) (defun GET-EN (/ NO-ENT EN MSG1 MSG2) (setq NO-ENT 1 EN NIL MSG1 "\nSelect a polyline: " MSG2 "\nNo polyline selected, try again." ) ; setq (while NO-ENT (setq EN (car (entsel MSG1))) (if (and EN (or (= (DXF 0 EN) "LWPOLYLINE") (= (DXF 0 EN) "POLYLINE")) ; or ) ; and (progn (setq NO-ENT NIL)) ; progn (prompt MSG2) ) ; if ) ; while EN ) ; get-en (defun GET-LWVLIST (EN / ELIST NUM-VERT VLIST) (setq ELIST (entget EN) NUM-VERT (cdr (assoc 90 ELIST)) ELIST (member (assoc 10 ELIST) ELIST) VLIST NIL ) ; setq (repeat NUM-VERT (setq VLIST (append VLIST (list (cdr (assoc 10 ELIST)))) ; append ) ; setq (setq ELIST (cdr ELIST) ELIST (member (assoc 10 ELIST) ELIST) ) ; setq ) ; repeat VLIST ) ; get-lwvlist (defun GET-PLVLIST (EN / VLIST) (setq VLIST NIL EN (entnext EN) ) ; setq (while (/= "SEQEND" (DXF 0 EN)) (setq VLIST (append VLIST (list (DXF 10 EN)))) (setq EN (entnext EN)) ) ; while VLIST ) ; get-plvlist (defun WRITE-IT (VLST EN / NEWVLIST MSG3 FNAME) (setq NEWVLIST (mapcar '(lambda (X) (trans X EN 0)) ;_ lambda VLST ) ;_ mapcar MSG3 "Polyline vertex file" ;FNAME (getfiled MSG3 "" "txt" 1) F1 (open "FNAME" "w") ) ; setq (WRITE-HEADER) (WRITE-VERTICES NEWVLIST) (setq F1 (close F1)) ) ;_ write-it (defun WRITE-HEADER (/ STR) (setq STR " POLYLINE VERTEX POINTS") (write-line STR F1) (setq STR (strcat " X " " Y " " Z") ;_ strcat ) ;_ setq (write-line STR F1) ) ;_ write-header (defun WRITE-VERTICES (NEWVLIST / XSTR YSTR ZSTR STR) (progn (initget "A B") (setq k (cond ((getkword "\nFor ground1 (Α)/ For ground2 (Β) < A > :" ) ) ("A") ) ) (if (eq k "A") (COMMAND "_layer" "_m" "ground1" "_c" "94" "" "") ) (if (eq k "B") (COMMAND "_layer" "_m" "ground2" "_c" "10" "" "") ) ) [color="red"](setq sk (/ (getreal "\n give the scale (100,200,500,etc) : ") 100)) (setq httt (* 0.0018 sk))[/color] (setq gptx (getpoint "\nBasepoint for X axis: ")) (setq gpty (getpoint "\nBasepoint for Y axis: ")) (foreach ITEM NEWVLIST (setq XSTR (rtos (nth 0 ITEM) 2 3) YSTR (rtos (nth 1 ITEM) 2 3) ZSTR (rtos (nth 2 ITEM) 2 3) STR (strcat XSTR (SPACES XSTR) YSTR (SPACES YSTR) ZSTR) ;_ strcat ) ; setq ; (write-line STR F1) (command "-style" "romans" "wgsimpl.shx" 0 1 0 "N" "N") (command "text" (list (+ (atof xstr) (/ (atof httt) 2.0)) (cadr gptx)) httt "0" (strcat xstr) ) (command "text" (list (+ (atof xstr) (/ (atof httt) 2.0)) (cadr gpty)) httt "0" (strcat ystr) ) ) ; foreach ) ; write-vertices (defun SPACES (STR / FIELD NUM CHAR SPACE) (setq FIELD 15 NUM (- FIELD (strlen STR)) CHAR " " SPACE "" ) ;_ setq (repeat NUM (setq SPACE (strcat SPACE CHAR))) ;_ repeat ) ;_ spaces (defun C:Test () (SETTING) (VERTEXT) (RESETTING) (princ)) ; c:nsl (prompt "\nEnter Test to start") Can any one fix this to choose for ground 1 automaticaly the datum and for the ground 2 to give manualy the datum draw parallel lines with ( line offset = 0.012 *scale) and center the text between them like example.dwg ? Thanks Quote
