Hi Everyone, I am pretty new to lisp routines and the codes so I was wondering if anybody could help me figure out why my autoarea.lsp will not work in AutoCAD map 2015. This is the routine I am using:
Code:
;;This program will calculate the area of irregular polygons ;;by picking an area inside the polygon. (defun C:AUTOAREA (/ ar en n num pt ss1) (if (not "acadapp.exp")(xload "acadapp.exp")) (setq n 0) (setq ss1 (ssadd)) (while (setq pt (getpoint "\nSelect internal point:")) (bpoly pt) ;;ADS function (setq ss1 (ssadd (entlast) ss1)) );;while (setq num (sslength ss1)) (command "area" "A" "E") (while (/= num n) (setq en (ssname ss1 n)) (command en) (setq n (1+ n)) );;while (command "" "") (command "erase" ss1 "") (command "redraw") (princ "\nThe area of the polygon in Square Meters is: ") (princ (cvunit (setq ar (getvar "AREA")) "SQ METER" "SQ METER")) (princ "\nThe area of the polygon in Square Feet is: ") (princ (cvunit (setq ar (getvar "AREA")) "SQ METER" "SQ FEET")) (princ "\nThe area of the polygon in hectares is: ") (princ (cvunit (setq ar (getvar "AREA")) "SQ METER" "HECTARE")) (princ "\nThe area of the polygon in acres is: ") (princ (cvunit (setq ar (getvar "AREA")) "SQ METER" "ACRE")) (setq ss nil) (prin1) );;end autoarea.lsp
Thanks in advance for any help into getting this routine to run again.
