Help with code.... ignoring blank lines and lines starting with a *
Hi, as above really, i have written the below code which ignores some of the blank lines lines starting with a * but not all of them.
can anyone see whats wrong with my code, it only ignores about half of the items??
       Dim FILE_NAME As String = "C:\test.dat"
       Dim RES As Boolean
       Dim TextLine() As String
       Dim i As VariantType
       Dim TEMPLINE As String
       i = 0
       If System.IO.File.Exists(FILE_NAME) = True Then
           Dim objReader As New System.IO.StreamReader(FILE_NAME)
           Do While objReader.Peek() <> -1
               TEMPLINE = objReader.ReadLine()
               Dim length As Integer = TEMPLINE.Length
               RES = TEMPLINE.StartsWith(Chr(42))
               If (CStr(RES)) = False Then
                   i = i + 2
                   ReDim Preserve TextLine(0 To i)
                   TextLine(i) = objReader.ReadLine()
                   MsgBox(TextLine(i))
                   'End If
               End If
           Loop
       Else
           MsgBox("File Does Not Exist")
       End If
forgot to say vb.net visual studio 2010
Thank you! :thumbsup:
Well... It is not written in C#. :rofl: *kidding*
In all seriousness, can you post a sample .DAT file for us to test?
Cheers
Like BB said a sample DAT file would be most helpful.
I had a similar problem a good while ago and the problem turned out to be the DAT not the code. I was getting the DAT from a third party piece of software and for some reason it was sometimes putting a space at the beginning of just some lines which was causing me all kind of problems. A simple TRIM function on the input string sorted it all out.
Have you tried using ("*") instead of (Chr(42))
Ben
