Hello all,
I have been looking into this all morning and I can not figure it out:
In a number of my drawings, in model space, hidden2 linetype does not display as .5x hidden linetype.
according to my acad.lin file everything is correct and in my drawing ltscale=1 msltscale=0 celtscale=1
I have attached a file with 3 lines, each one set to hidden, hidden2 and hidden2x respectively
ltscale_issues.dwg
There is a mixture of linetypes definitions in your drawing. Hidden2 is the correct definition for an Imperial drawing, but Hidden and HiddenX2 are metric linetype definition (acadiso.lin)
Type LINETYPE at the command line, then "Load". Pick linetype you wish to reload from the available linetypes in acad.lin (you can use Shift or CTRL to select multiple at once) then click "OK" and choose the option to reload them.
[ATTACH=CONFIG]52584[/ATTACH]
Thank you Nestly! This was driving me insane all morning! I never would have guessed that was the problem, thank you!
