Curve driven pattern on curved surface :)
Hi there...
...I'm having a problem with this and I'm not sure it is possible to solve this as it is on the pic in attachment.
I need to create pattern on curved surface, and the body which has to be patterned has also irregular shape :(.
Pls, help me with this...I'm desperate. I'm sending you pic in attachment...it's that sole network
Thanks!
No, no....in Solidworks...2013...sorry, i haven't mentioned... :)
As an Autocad answer I guess similar in solid works you create a roller coaster pattern use it as a path to extrude a tube, array it in two directions and you have the mesh pattern clip edges to the shoe shape. The edge tubes similar but a bit more difficult need to place and array around edge. If the shoe is curved then placing the roller coaster tubes will require a bit more effort but achiveable.
