Hi,
I am trying something very simple, but I am out of ideas already
(setq interval 5)
(setq dist (getdist "\nEnter Interval :"))
Chavdar
Hi Chavdar,
if you mean the interval value in the prompt, perhaps something like this
(setq interval 5)
(setq dist (getdist (strcat "\nEnter Interval < " (itoa interval)" >:")))
EDIT: If your goal is to force the user to enter a number divisible by 5, maybe something like this
(setq interval 5)
(while (not
          (initget 7)
          (setq dist (getreal (strcat "\nEnter Interval < " (itoa interval) " >:")))
          (= (fix (/ dist 5)) (/ dist 5))
Henrique
Edited by hmsilva
To check for divisibility, you could also use:
(zerop (rem dist 5))
More concise.
Thank you Lee!
Henrique
  • 7 months later...
what is it means by rem dist ?
The expression returns the remainder when dividing the numerical value held by the variable 'dist' by 5.
