atr140 Posted February 2, 2015 Share Posted February 2, 2015 I am very new to using lisp routines, so please excuse my ignorance. I have noticed that I have been using AutoCAD to get the sectional properties of built up sections quite often. To do this, I generally draw the shape, make it a region, and use massprop to get the centroid, area, moment of inertia, etc of the shape. I would then copy and paste the info onto a titleblock along with the shape, and manually enter the centroid (place a point and change the point style in order to easily see it once it is printed) I know there is an easier way, but again I am a newbie. After searching a bit, I found a way to draw a point at the centroid of a region. (defun c:gecen(/ cSetcLst oldSnp) (vl-load-com) (princ "\n<<<Select Regions or 3D-solids >>> ") (if(setq cSet(ssget '((0 . "REGION,3DSOLID")))) (progn (setq cLst(mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr(ssnamex cSet)))) oldSnp(getvar "OSMODE") ); end setq (mapcar 'setvar (list "OSMODE" "CMDECHO")(list 0 0)) (foreach ent cLst (if(vlax-property-available-p ent 'Centroid) (command "_.point"(vlax-get ent 'Centroid)) ); end if ); end foreach (mapcar 'setvar (list "OSMODE" "CMDECHO")(list oldSnp 1)) ); end progn ); end if (princ) ); end of c:gecen What I am missing is grabbing the sectional properties information (area, centroid, moment of inertia, etc) and putting it in a textbox. Ideally, I would like to update a pre-existing textbox set in paperspace on titleblock. I could then fit the shape into a window on paperspace and print out all of the information. I appreciate any and all help on this matter! Thank you in advance! Quote Link to comment Share on other sites More sharing options...
Tharwat Posted February 3, 2015 Share Posted February 3, 2015 (edited) Firstly welcome to CADTutor . Secondly most of what you are doing could be done with a lisp program , so it is better to give an example with a drawing showing BEFORE and AFTER to allow users to get your point very clearly and to write a program in one shot Edited February 3, 2015 by Tharwat typo Quote Link to comment Share on other sites More sharing options...
atr140 Posted February 3, 2015 Author Share Posted February 3, 2015 Tharwat, Thanks for the reply and suggestion! Please see attached for my vision I would like to be able to draw a polygon, and run one command that will draw a point at the centroid, and fill in the "blanks" of all the sectional properties. I know that in order to use massprop (as i have done in the past) the polygon must be a region and the bottom left should be at (0,0). If this could be done without converting it to a region, and to make the centroid relative to the object that would be great! Please let me know if any other clarification is needed! Thanks for the help Aaron Here is the example... http://www.filedropper.com/example_9 Quote Link to comment Share on other sites More sharing options...
Tharwat Posted February 3, 2015 Share Posted February 3, 2015 One question at the mean time , how would you draw the polygon ? do you have a list of points or just by the command pline ? It is late here for now , so tomorrow morning will continue after you answer the above mentioned question(s) . Quote Link to comment Share on other sites More sharing options...
atr140 Posted February 3, 2015 Author Share Posted February 3, 2015 Tharwat, I will be using the pline command or just line segments. I can make sure I always covert the line segments into a polyline. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted February 4, 2015 Share Posted February 4, 2015 I couldn't download the file , upload it here by going to button Go Advanced which is on the bottom right side hand of this page and press attach to collect the required sample drawing . Quote Link to comment Share on other sites More sharing options...
Tharwat Posted February 4, 2015 Share Posted February 4, 2015 No worries , after many times of trying I could have downloaded the drawing I see that you have the polyline drawing in Model space and the Mtext is in paper space ? although you don't want to select the Mtext to replace or add value because as it is clear from the drawing , you want to place the values in order on each line that is on the right side of the Mtext object . Suggestion : don't you think that it could be much better if you replaced the Mtext with Attributed Block ? furthermore that would be much more easier to fulfill the values in its correct location than the way you go now with Mtext . Quote Link to comment Share on other sites More sharing options...
atr140 Posted February 4, 2015 Author Share Posted February 4, 2015 That is a great idea. I like the idea of setting up attributes. I will take some time later today to update that. Good suggestion! Quote Link to comment Share on other sites More sharing options...
Tharwat Posted February 4, 2015 Share Posted February 4, 2015 That is a great idea. I like the idea of setting up attributes. I will take some time later today to update that. Good suggestion! Good stuff Can you explain what is the meaning of the last two chars in the Mtext object ( l J ) or what they represent ? Quote Link to comment Share on other sites More sharing options...
atr140 Posted February 4, 2015 Author Share Posted February 4, 2015 The principal moments are the moments along the principal axes, with the origin at the centroid. They are related to the principal axes, rather than any other coordinate system which might be defined. They are characteristics of the object, in other words. Quote Link to comment Share on other sites More sharing options...
atr140 Posted February 4, 2015 Author Share Posted February 4, 2015 I updated the drawing to add the attirbuted block, however I could not upload it! It is giving me a max upload limit of 1000 KB?? Am I doing something wrong. Sorry for the complication! Here is a link. http://www.filedropper.com/example_10 Sorry again! Quote Link to comment Share on other sites More sharing options...
Tharwat Posted February 5, 2015 Share Posted February 5, 2015 (edited) Here we go now . Process of the program : You should select a CLOSED polyline and after that the program would search for the attributed block entitled SECPROP then write the value to each attributed text string in the block . NOTE: the program would write the values ONLY to one BLOCK that would be found , so if you have any plans to select the fore-said block , it is simple to revise the program accordingly . Try the program on your last attached drawing but you should pick a closed polyline as I have mentioned earlier . Let me know how things going on with you . Good luck (defun c:Test (/ cl o lst b) ;;; -------------------------- ;;; ;;; Author : Tharwat Al Shoufi ;;; ;;; Date : 05.February.2015 ;;; ;;; -------------------------- ;;; (defun _reg (o / r l e p d vls) (if (zerop (getvar 'PDMODE)) (setvar 'PDMODE 34) ) (if (eq (cdr (assoc 0 (entget (ssname o 0)))) "REGION") (setq r (list (vlax-ename->vla-object (ssname o 0)))) (setq r (vl-catch-all-apply 'vlax-invoke (list (vla-get-block (vla-get-activelayout (vla-get-ActiveDocument (vlax-get-acad-object) ) ) ) 'Addregion (list (vlax-ename->vla-object (ssname o 0))) ) ) d t ) ) (if r (progn (entmake (list '(0 . "POINT") (cons 10 (setq p (vlax-get (car r) 'Centroid))))) (setq e (car r) vls (mapcar '(lambda (x) (vlax-safearray->list (vlax-variant-value x))) (list (vla-get-MomentOfInertia e) (vla-get-radiiofgyration e) (vla-get-PrincipalMoments e) ) ) l (list (vla-get-area e) (vla-get-perimeter e) (car p) (cadr p) (caar vls) (cadar vls) (caadr vls) (cadr (cadr vls)) (caaddr vls) (cadr (caddr vls)) ) ) (if d (vla-delete e)) ) ) l ) (if (and (if (or (minusp (cdr (assoc 62 (setq cl (entget (tblobjname "LAYER" (getvar 'CLAYER))))))) (= 4 (logand 4 (cdr (assoc 70 cl)))) ) (progn (alert "<!> Current Layer is either OFF or LOCKED <!>") nil) t ) (if (not (setq b (ssget "_X" '((0 . "INSERT") (66 . 1) (2 . "SECPROP"))))) (progn (alert "Couldn't find any attributed block entitled < SECPROP > !!") nil ) t) (princ "\n Select CLOSED Object [REGION,CIRCLE,ELLIPSE,LWpolyline] :") (if (not (setq o (ssget "_+.:S:E" '((-4 . "<OR") (0 . "REGION,CIRCLE,ELLIPSE") (-4 . "<AND") (0 . "LWPOLYLINE") (-4 . "&=") (70 . 1) (-4 . "AND>") (-4 . "OR>"))))) (progn (alert "\n << Invalid Object !! >>") nil) t ) (setq lst (_reg o)) ) (mapcar '(lambda (x v) (if v (vla-put-textstring x (rtos v 2 2)))) (vlax-invoke (vlax-ename->vla-object (ssname b 0)) 'getattributes) (reverse lst) ) ) (princ) )(vl-load-com) Edited February 5, 2015 by Tharwat Program updated as been required Quote Link to comment Share on other sites More sharing options...
Manila Wolf Posted February 5, 2015 Share Posted February 5, 2015 Hi Tharwat, I am following this thread with interest. Just throwing some thoughts in here and I hope I am not treading on anybody's toes, but it may be better to make the target shape a region rather than a closed polyline. I am thinking about when the target profile is a hollow box or tube. I can see that you are following the OP's request. Just thinking that the occasion may crop up in the future. Or....... Make an option to pick either a closed polyline or a region. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted February 5, 2015 Share Posted February 5, 2015 Hi Tharwat,I am following this thread with interest. I am really happy that you interests in this thread . Or....... Make an option to pick either a closed polyline or a region. Yeah , I have thought of that but since that was the first draft of the program that I have posted , I wanted to know the OP's opinion then we may can expand the program to the limits we looking for and as much as the experience can serves me . Quote Link to comment Share on other sites More sharing options...
Manila Wolf Posted February 5, 2015 Share Posted February 5, 2015 Yes Tharwat, I should really let the OP comment first. I must say that I am already liking what you have produced so far. Cheers and keep up the good work. Quote Link to comment Share on other sites More sharing options...
atr140 Posted February 5, 2015 Author Share Posted February 5, 2015 I tried the program and it works great! I am very pleased. I do think I prefer the idea of being able to select a region or polyline. I do work with hollow tubes as well. Another thought, can we round all the values to 2 decimals? Cheers to you!!! Good work! Quote Link to comment Share on other sites More sharing options...
Tharwat Posted February 5, 2015 Share Posted February 5, 2015 I tried the program and it works great! I am very pleased. .... Cheers to you!!! Good work! I am really happy to hear that , and you are welcome anytime . I do think I prefer the idea of being able to select a region or polyline. I do work with hollow tubes as well. As you know if you select a closed polyline or object a region would be created and delete at the end of the program and that is not visible to user to see , so do you want to delete the region if the user selected a region after all ? can we round all the values to 2 decimals? Sure we can . Quote Link to comment Share on other sites More sharing options...
Tharwat Posted February 5, 2015 Share Posted February 5, 2015 Anyway , I updated the program and added more options than the ones that have been required to become almost a watertight program . Try it gentle men and let me know . Good luck . Quote Link to comment Share on other sites More sharing options...
atr140 Posted February 5, 2015 Author Share Posted February 5, 2015 Fantastic... tested to perfection!!! Quote Link to comment Share on other sites More sharing options...
Tharwat Posted February 5, 2015 Share Posted February 5, 2015 Fantastic... tested to perfection!!! Excellent , happy to hear that . Quote Link to comment Share on other sites More sharing options...
