vb code to open drawings in autocad lt
i have autocad2007 and autocad LT 2006 in my system i want to open dwg files in autccad Lt 2006 using vb.6 code.
i want to modify the above code and open dwg drawings in Lt
else looking for suitable vb.6 code
Dim DwgName As String
       On Error Resume Next
       Set acadApp = GetObject(, "AutoCAD.Application")
       If Err Then
           Set acadApp = CreateObject("AutoCAD .Application")
           Err.Clear
       End If
'        If Right(App.Path, 1) = "\" Then
'            DwgName = "C:\13027167-GX2.dwg"
'        Else
'        End If
       Set acadDoc = acadApp.ActiveDocument
       If acadDoc.FullName <> DwgName Then
           acadDoc.Open DwgName
       End If
       Dim str As String, str1 As String
       str1 = "_-insert" & vbLf & """" & "C:\14001120-AA8232-AC8232-AZ665.dwg" & """" & vbLf & "0,0,0" & vbLf & vbLf & vbLf & vbLf & "z" & vbLf & "a" & vbLf
       'str = "dwin" & vbLf
       acadDoc.SendCommand str1
      ' acadDoc.SendCommand str
       acadApp.Visible = True
I do not believe the LT version can be accessed with VB in it's present state.
That's right. You have no COM interface in LT, so you have nothing like
Set acadLTApp = CreateObject("AutoCADLT.Application")
You can get lisp in LT with LT-Extender.
You can "run" a dwg file in Windows with VB, this will open it in LT if you have the file association.
i do agree but if u have only LT or autocad 2007 in system then this shell command can be used to open the drawing
but i want to pass some values in command line which i dotn know how to do it in lt
Option Explicit
Private Declare Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" ( _
                   ByVal hwnd As Long, _
                   ByVal lpOperation As String, _
                   ByVal lpFile As String, _
                   ByVal lpParameters As String, _
                   ByVal lpDirectory As String, _
                   ByVal nShowCmd As Long) As Long
Private Const SW_HIDE As Long = 0
Private Const SW_SHOWNORMAL As Long = 1
Private Const SW_SHOWMAXIMIZED As Long = 3
Private Const SW_SHOWMINIMIZED As Long = 2
Private Sub Command1_Click()
   ShellExecute Me.hwnd, "open", "C:\Users\Public\Test1.dwg", vbNullString, "C:\", SW_SHOWNORMAL
End Sub
where can i get LT-Extender. is it free version?
hello Ragnar Thor
i have downloaded briscad trail version
ple help me out with vb.6 code to open and also to inset dwg drawings
regards
sam
It is almost the same as for AUtoCAD.
For example:
   Dim bcad As AcadApplication
   Dim I As Integer
Retry:   'In case Bricscad is closing down
   Set bcad = GetObject("", "BricscadApp.AcadApplication")
   If Err = -2147023179 Then
       I = I + 1
       Err.Clear
       If I > 1000 Then Exit Function
       GoTo Retry
   Set bcad = CreateObject("BricscadApp.AcadApplication")
   End If
   bcad.Visible = True
