Hi I am ajith .I need a lisp program to find end points of autocad drawing and display its dimention with reference to x or y plane
Start playing with (getvar "extmin").
You would probably guess on "extmax" also.
This will give you a list of x,y,z for the min an max of the drawing's extents.
Can you send code to find all end points of a drawing
Try this:
(defun c:dwgdim    (/ bt tp)
   (setq bt (getvar "extmin")
     tp (getvar "extmax")
   ) ;_  end setq
   (alert (strcat "Drawing Dimensions are: \n"
          (rtos (- (car tp) (car bt)) 2 2)
          " x "
          (rtos (- (cadr tp) (cadr bt)) 2 2)
      ) ;_  end strcat
   ) ;_  end alert
) ;_  end defun
But it probably would have benefitted you more to experiment with the variables yourself.
I agree, but you where kind :)
Cheers Raggi,
I must say, you pretty much spelled out how to create the code, but as he stubbornly still requested the code to be posted, I thought I'd experiment, as I too had never used the extmin and extmax variables - pretty useful it turns out.
