Hello everyone.
I have a questionabout "apply" and "mapcar".
Please looks bellow code:
(setq b '((0 1 2) (3 4 5) (6 7 ))
(apply 'mapcar (cons 'list b))
it return : ((0 3 6 ) (1 4 7 ) (2 5 8 ) )
how it works?
and next question:
(setq a '(1 2 3 4 5 6 7 8 9 0))
(apply 'mapcar (cons 'list (list a (cdr a))))
it return : ( (1 2) (2 3) (3 4) (4 5) (5 6) (6 7) (7 8 ) (8 9) (9 0) )
how it works also?
Welcome to CADTutor .
Hope that I could describe them as clear as you looking for :)
The first function apply implement the mapcar function on a list of lists and mapcar function iterate through each element of every list and with the use of cons and list functions you have them gathered in a list of lists as well .
The second question is also implement the mapcar function with the use of apply function to get the first and the second item of the list separately and I can offer you as alternative function in recursive manner.
(defun _list  (l)
;;;  Tharwat . 05.02.2015    ;;;
 (if (> (length l) 1)
   (cons (list (car l) (cadr l)) (_list (cdr l))))
To test the above function :
(_list '(1 2 3 4 5 6 7 8 9 0))
[color=red];; Returns [/color]
((1 2) (2 3) (3 4) (4 5) (5 6) (6 7) (7  (8 9) (9 0))
Thanks to you, Mr.Tharwat !
But i still confuse on some details.
First,
I know the mapcar function just like foreach. In code 1 , why the next value is "3" not "1" ?
please looks other example :
(setq lst '((3 4 5) (0 1 2) (6 7 ))
(apply 'mapcar (cons 'min lst))
the result shows (0 1 2)
why its not (3 0 6)?
Second,
Why add the list(using apostrope for not to evulate) in fornt of a list , and using apply can gather the list?
Thanks!
First,
Because the mapcar function iterate through each first element of the target list first then the second then the third .... to the end .
Because the minimum values for the target list is consist of three element and the outcome came in three including the minimum numbers .
Second,
That required from the mapcar function , first apply function needs a function as a first argument then the mapcar function also requires a function as a first argument .
I am happy with your questions because that also refresh my memory with the fore-said functions :)
Thanks you !
I have clear understand those function after yours explaination!
Thanks you !
happy to hear that and you are most welcome .
Keep on practicing with functions to become familiar with them and don't be surprised or panic if you one day have noticed that a specific function doing something than you
used to see or to know :lol: an example one is the entdel function .
how it works?
Consider that:
(apply 'mapcar (cons 'list '((0 1 2) (3 4 5) (6 7 )))
Is the same as:
(mapcar 'list '(0 1 2) '(3 4 5) '(6 7 )
Which evaluates in the same way as:
(list (list 0 3 6) (list 1 4 7) (list 2 5 )
Returning:
((0 3 6) (1 4 7) (2 5 )
Thanks you also , Mr. Lee Mac!
I try other example, it really amazing.
But why using apply and mapcar , why not just using mapcar?
Is that any reasons ? much faster ?
Thanks!
You're welcome!
The function or functions required depends on the format of the input data, the operations that are to be performed, and the required format for the list that is returned - in your particular example, if each list of three elements is nested within a parent list, this list would be supplied to mapcar as a single argument and would not return the same result:
_$ (mapcar 'list '((0 1 2) (3 4 5) (6 7 ))
(((0 1 2)) ((3 4 5)) ((6 7 ))
Hence the apply function is used to construct an expression equivalent to:
